First post, by Cobra!
As the title says, I'm trying to get Glover installed on my Windows 7 PC, but when I click on the setup exe, nothing happens. Task manager shows the installer as running, but nothing shows on Windows itself.
What do I do?
Reply 1 of 15, by Davros
install it in an xp system and copy the files open
or get xp mode for win7 and copy the files over
https://www.microsoft.com/en-gb/download/deta … ls.aspx?id=8002
Reply 4 of 15, by Cobra!
Okay, I found the registers it installed on the VM, and copied them over to windows.
The config still doesn't run, but now the game starts, but it keeps flashing and runs really slow.
I found that there's a 3Dfx option on the config, which I can't access, and copying over the .cfg file doesn't change anything.
EDIT: I tried to copy the registries, hoping that the config was saved there, and the game runs as it should but it still flashes and flickers.
Reply 10 of 15, by ZellSF
Cobra! wrote:
You mean close any other applications that are running?
No all background processes (applications implies foreground applications only imo).
Or if you have a newer Windows version just find the installer executable in task manager and click "Analyze wait chain" and just kill whatever process is holding it up.
