First post, by JoJoAndy
Hi, I have problem with "Dreamfall: The Longest Journey" I have old BOX version of this game. There is no problem installing it, but when i try to run it, popup says that game not meets minimum requirements and game dont run. Does someone know way to run it.
My PC spec are:
Windows 10 64 bit
CPU: Intel Core i5 8400 2.80 GHz
GPU: GeForce GTX 1060 3GB
RAM: 8GB
Reply 1 of 2, by F2bnp
I don't know if this will fix it, but have you tried applying the latest patch? It removes the StarForce DRM which will not otherwise run on Windows 10.
Alternatively, you can try the GOG version.
Reply 2 of 2, by JoJoAndy
Thanks to patch that you linked it works, but unfortunately i have Polish version of this game and patch change subtitle to English, but i can change voice to Polish, do you know any solution to this?
