First post, by FabioB
Hi.
This game works on Windows 10 with compatibility set to Windows 95. However the game speedup and slowdown continuously in a matter of seconds making it unplayable...
Set the processor affinity to 1 core but to no avail.
Suggestions?
Reply 1 of 2, by filipetolhuizen
This is normal behaviour in this game under modern OSes. Unfortunatelly the MMX patch doesn't fix this. Here in this forum you can find a rare D3D customized patch for it which should improve gameplay a lot. If you have a nvidia card you can use nvidiainspector to create a custom profile for the game to limit its fps.
Reply 2 of 2, by VirtuaIceMan
On my old XP machine I had to run DXDiag in the background to prevent the framerate doing that. On my current Win10 PC it seems fine (though not tested it for a while).
Unofficial Direct3D patch is here: Re: Sega Rally Championship Unofficial Direct3D patch & mod
