First post, by strucker
Hi!! I have installed windows 3.1 on dosbox. I have the "autoexec" config to autorun windows 3.1.
Can i 'hide' the dosbox prompt? I mean, open dosbox and only see the windows boot and not the ms-dos command line.
Thanks!
Thanks!
Are you packaging this game for someone else because you're being pretty OCD about this stuff....
You can try @ECHO OFF and perhaps a CLS mabye.
wrote:Are you packaging this game for someone else because you're being pretty OCD about this stuff....
hahaha you are right, it's for my cousins. I want to make it simple and clean as possible.
Anyway, thanks a lot for all the help!
wrote:I want to make it simple and clean as possible.
But using a computer in early nineties was far from simple and clean.
Seeing cryptic messages when the system booted was the norm, and it still is in many Linux and BSD distros.
wrote:wrote:I want to make it simple and clean as possible.
Uncompressing vmlinuz...
try (in autoexec.bat)
cls
prompt $h
