First post, by Boogeyman
- Newbie
I can't get Rayman Mapper to run properly. I can load it up, but when I select a world I get this message: Error in Installation File (ubi.ini)
Sorry for bumping such an old thread, but when googling this error:
This thread in the only result.
After not being able to find any help on the net, I managed to fix the problem myself, all I had to do was copy the:
%windir%\Ubisoft
Folder to the game installation folder (default is c:\ubisoft\raykit).
I hope it will help other people with the same problem.
P.S. There is a "patch" (It's actually just an installer+DOSBox) for Rayman Gold (aka Rayman Designer or Rayman World) by Opaquit (pok2) which also solves this problem. I found out about it only after I fixed this error by copying the directory mentioned above.
