Problematic Windows games list
Reply 120 of 127, by ZellSF
SpinalBlood wrote on 2020-06-18, 02:15:
ZellSF wrote on 2020-06-16, 13:49:
Did you read the later post I made? There's a winmm patcher that might be easier: https://w.atwiki.jp/nectaris/pages/22.html Ass […]
SpinalBlood wrote on 2020-06-08, 02:29:
I would like to write more about this since I had this problem for years in the past, until I followed the instructions in 2014 and they worked for me;
Assuming it forwards all other winmm events correctly (cdda music and gamepad support are often controlled by winmm) which I haven't had time to test.
SpinalBlood wrote:
For Windows 7 64bit I manually did the modify in mciseq.dll in the Syswow64 folder
Overwriting the system file might not be necessary, it wasn't for Nectaris, I could just place a modified mciseq.dll in the game's directory.
Micro Machines V3 is another game that has the same problem.
Sorry I missed the post. Since my last OS reinstall I didn't tweak with the mciseq file yet, so I tried to put mciseq.dll in the screensavers (with midi included) folder and... it worked, I didn't think about this clever solution (it's true that often games can start with some dll in its folder rather than in windows system itself...) Thank you
About the winmm patcher I don't quite get how it works; I must patch that dll with the exe then put it in the app of choice folder?
You patch the game exe with winm_patcher (drag and drop the game's exe over the patcher) and then place winm_.dll in the game directory.
Reply 121 of 127, by SpinalBlood
I have tried with a certain game but it doesn't seem to be working
Maybe the patcher is designed only for nectaris?
If I drag&drop the exe, after I press enter the windows closes and it looks like the exe file has not been touched
But anyway the mciseq.dll "in-folder "solution is very handy and seems working so that is more than enough (at least with the "freeze programs" that I have encountered so far)
Reply 123 of 127, by Discrete_BOB_058
Jane's USNF doesnt work
YouTube Channel:
DEADHistory Walkthroughs
PC SPECS:-
CPU: AMD Ryzen 5 1600
GPU: ZOTAC NVIDIA GeForce GTX 1050Ti OC Edition
RAM: 8GB*2 Corsair Vengeance LPX DDR4 2400MHz
Motherboard: Gigabyte Aorus B450M
PSU: Corsair VX550
Sound Card: Realtek ALC892
Reply 125 of 127, by Discrete_BOB_058
leileilol wrote on 2020-08-08, 15:12:
Discrete_BOB_058 wrote on 2020-08-08, 10:21:
that's a dos game
that was released on 1996 for windows also. It starts and then crashes
YouTube Channel:
PC SPECS:-
PSU: Corsair VX550
Reply 126 of 127, by Discrete_BOB_058
Well, you can play The Need for Speed Special Edition on Windows 10 and Windows 7, if you go Re: The Need for Speed Special Edition for Windows doesn't work
The problem my PC had was the headset DRIVER.
YouTube Channel:
PC SPECS:-
PSU: Corsair VX550
Reply 127 of 127, by Davros
discrete bob i have a working janes usaf i cant remember where i got the patch from but i'm sure if you replace some of your files with mine you can get it working
make sure you've patched to 1.02
pm me your email address
edit : it may have been this
https://www.moddb.com/games/janes-united-states-air-force
Edit 2: I have the latest version
