First post, by AvalonH
- Member
Trying to run this game on Win-10 and XP gives the same error message : KNIGHTS.EXE
"The instruction at 00000000 referenced memory at 00000000
The memory could not be read from
Click on OK to terminate the application"
Tried all the usual compatibility fixes available in windows, single core only, and slowing CPU down with no luck so far. Game uses WING but I have that installed and checked with process monitor that it finds and loads those dlls.
This game is pretty interesting as it shows what the original Alone in the Dark 1-3 engine would look like in SVGA. The more common earlier Europe release of this game was Dos only without an SVGA mode.
