1. Install Prince of Persia 3D from CD1
2. Extract PoP3D_Unpacked_Patch_v1.01.rar to the installation folder, overwrite all file […]
2. Extract PoP3D_Unpacked_Patch_v1.01.rar to the installation folder, overwrite all files.
3. Extract the POP3D NOCD.rar patch in the installation dir, overwrite exe file.
4. Extract dgVoodoo to the installation dir and run dgVoodooCpl.exe. Go to the DirectX tab, set forced resolution, max VRAM to 128 MB (don't set it higher, seems to work better with max 128). Hit Apply & OK.
5. Install Riva Tuner. In the RivaTuner configuration, add the game exe and set a frame cap of 60 FPS.
6. Copy options.sav from the pop3d-resolutions.zip (the one from 1920 x 1080 should work fine for 2560 x 1440 too)
6. IMPORTANT: Even with the NO CD patch, CD2 must be inserted in order to play the game! So.... insert it now! 😀
7. Run the game (on the first try it might not work, until Windows 10 first applies the compatibility settings automatically).
8. After the game starts, sometimes the performance can be pretty bad (6 - 7 FPS) and CPU usage (as shown by MSI afterburner with RivaTuner) is very high on one core: 100%.
The workaround for this is to start the game, load the level (don't do this while in the menu) and then hit ALT - TAB.
This will minimize the game and after you maximize it again, CPU usage will have decreased to 30 - 40% and performance will be perfect. If the prince keeps jumping after you return to the game, hit the ALT key a few more times and he will stop 😀 FYI, this issue seems to go away after some time (maybe in some cases it won't even appear in the first place).
NOTE: If you want to see the intro movies, you must install "Quicktime alternative.rar" (located in the "OTHER TOOLS & PATCHES" folder)
SOLUTIONS FOR POTENTIAL ISSUES:
1. In case of problems during startup: first thing to try is disabling DPI scaling (Right click on desktop --> Display settings --> Change the size of text, apps and other items --> 100%. If this is higher than 100%, it can cause many issues with old games!
2. In the second level, when you enter the water there are some graphical issues with dgVoodoo (missing textures, basically you can't see anything while you are submerged in the pool).
The workaround is to use DDrawCompat v0.2.1.zip instead of dgvoodoo (just delete the dgvoodoo files and extract the ddraw.dll in the game dir).
Make sure to disable DPI scaling as specified above (or you can try the settings in DPI_compatibility_settings.jpg) and copy again the options.sav for 1920x1080
(the disadvantage is that the game will not be forced to run at 2560x1440, so with DDrawCompat v0.2.1 the game will run at maximum FullHD, but at least you can get passed the water swimming sequence).
3. If you have issues with missing textures use the Geometry patch.
- Delete the <game dir>/Geometry folder
- Extract the Geometry archive in the game dir.
For further problems, visit website: http://popuw.com/download3.html
