First post, by filipetolhuizen
Hello,
On my system VPHall CD is not being recognized even after installing the latest patch (2.5.9.2). Using a fixed .exe doesn't help either. I've been able to fix a few games by updating the security protection drivers and others by simply enabling security protections that were disabled by some Windows Updates. For VPHall is there such a method to get it working? I'm on Win7 64 bits.
Reply 2 of 8, by filipetolhuizen
ZellSF wrote on 2020-05-04, 12:42:
Works fine here. Even when I switch the drive letter of the virtual drive I used (seems it checks all CD drives)? Maybe your disc is just bad.
Are you using any compatibility fixes?
Reply 4 of 8, by filipetolhuizen
Ok, turned out I accidentally moved a folder inside another one, but now I'm getting a different error. "Unable to load profile.dll" even if it's there already. Tried both the patched and unpatched dll without success.
Edit: Did a fresh reinstall and now the CD Not in drive message is back again. I don't know what to do anymore.
Reply 5 of 8, by ZellSF
filipetolhuizen wrote on 2020-05-05, 00:41:
Check the disc for errors?
Reply 7 of 8, by psy_
Hello, i was having the same problems and the game managed to run when i mount a virtual cd iso image , i can pm you my exe to try it if you want. (xmm for some reason i can'r send pm's , because i don't have many posts i think 😒 )
Reply 8 of 8, by filipetolhuizen
psy_ wrote on 2020-09-09, 15:58:
Hello, I haven't updated this thread in a long while but this is exactly how I managed to run it before, thanks. For some reason the nocd doesn't work on Win7 and above and in WinXP only for some days.
