First post, by boywndr1982
Anybody tried installing The Daedalus Encounter in xp?
The autorun gives this error
this application requires windows NT v3.5 or later
if you run the install with the compatibility mode you get this half way through:
Not enough disk space on target drive while attempting to copy files
even if there is plenty of space. I tried a fat32 partition but that didn't help. Any ideas?
