Reply 20 of 38, by Gamecollector
Gex 2 is glide or d3d+glide.
IIRC the EU version (Ubi-Soft) is glide only.
The US version (Eidos) is d3d only. And there is the glide patch for this version.
Reply 21 of 38, by derpmochump
Garrett W wrote on 2020-07-25, 00:14:
Fairly certain Dreams to Reality only runs on the original Voodoo (and perhaps Voodoo Rush). Even Voodoo2 can't run it apparently.
okay thanks.
P4SCE mobo/prescott p4 3ghz/4gb ddr1 in dual channel voodoo 3000 PCI @187mhz
3dfx ref. drivers / win98se with memory patch to boot with 4gb(1gb used)
dual boot with winXP-32 bit running amigasport 3.0 3dfx drivers
Reply 28 of 38, by willow
robertmo wrote on 2020-08-15, 17:10:
if a game runs in higher resolutions with dgvoodoo2 then it is using d3d 5 or more
It's not true.
Lands of lore 2 win95 version use only directx3.0a (only dos version use glide) and you can run in higher version with dgvoodoo2.
Reply 30 of 38, by willow
robertmo wrote on 2020-08-16, 14:37:
if you want you can post a screenshot when looking at the pool
but when you look at the pool you notice the uneven blocky line of the edge of the pool
I have just tried this afternoon and force higer resolution works with lands of lore 2 win 95 dx3.0a version.
640x480
2560x1440
640x480 stretched
If the pool is in 2D, it's normal.
Force resolution doesn't change 2d elements like sprite. It's change only 3d elements.
LoL 2 have lot's of 2d elements.
Reply 31 of 38, by ZellSF
Lands of Lore II's Direct3D render has a lot of issues btw, the DOS Glide render is a lot better if you want to play the game. It isn't fun to get that working on modern systems though, especially not if you want resolution forcing.
Resolution forcing definitely works for the Direct3D version, but it causes glitches with some graphical effects.
Reply 34 of 38, by Discrete_BOB_058
Civilization 2
Knight's Chase
YouTube Channel:
DEADHistory Walkthroughs
PC SPECS:-
CPU: AMD Ryzen 5 1600
GPU: ZOTAC NVIDIA GeForce GTX 1050Ti OC Edition
RAM: 8GB*2 Corsair Vengeance LPX DDR4 2400MHz
Motherboard: Gigabyte Aorus B450M
PSU: Corsair VX550
Sound Card: Realtek ALC892
Reply 35 of 38, by Discrete_BOB_058
robertmo wrote on 2020-08-15, 13:12:
ok, it looks games using direct3d from directx 2 or 3 cannot be really counted as using direct3d.
we have to wipe out all d3d 2 and 3 only games from the list
unlocking the thread
Some games get to a higher resooution, like Moto Racer and Daytona USA, using dgVoodoo. They are dx2 and dx3 games. Do they qualify for this?
YouTube Channel:
PC SPECS:-
PSU: Corsair VX550
Reply 37 of 38, by Discrete_BOB_058
This list is in the top, how to do that. I also want to keep my list of dx8.1 and older games running on win10 list on top like this
YouTube Channel:
PC SPECS:-
PSU: Corsair VX550
