First post, by Chadti99
Hello,
Is there a guide on how to get the GOG version of MotoRacer working on a Windows 98 machine with a Voodoo2?
Alternatively is there another website I could purchase a legit copy from that would work?
I’m getting the following error when I click Solo play with the GOG version.
TIA for any help!
Reply 1 of 8, by Discrete_BOB_058
Chadti99 wrote on 2020-08-27, 01:31:
Hello, […]
Hello,
TIA for any help!
Did you install the game on the machine, I think you should trace the registry when you install it natively. The original CD worked fine on current gen OS, and I just had to put the CD. There should be registry or configs regarding CD.
YouTube Channel:
DEADHistory Walkthroughs
PC SPECS:-
CPU: AMD Ryzen 5 1600
GPU: ZOTAC NVIDIA GeForce GTX 1050Ti OC Edition
RAM: 8GB*2 Corsair Vengeance LPX DDR4 2400MHz
Motherboard: Gigabyte Aorus B450M
PSU: Corsair VX550
Sound Card: Realtek ALC892
Reply 2 of 8, by Chadti99
Discrete_BOB_058 wrote on 2020-08-27, 03:53:
Hello, […]
Hello,
TIA for any help!
Okay I just tried an “original” CD and the game freezes when I click Start at this screen. So I’m getting a bit further. This is with the 3.22 patch applied that is supposed to fix freezing issues with Voodoo 2.
Reply 3 of 8, by Discrete_BOB_058
Chadti99 wrote on 2020-08-27, 11:24:
Hello, […]
Hello,
TIA for any help!
I used a D3D card so I am not sure, I think you should reinstall the drivers, both DX and Voodoo
YouTube Channel:
PC SPECS:-
PSU: Corsair VX550
Reply 5 of 8, by Chadti99
filipetolhuizen wrote on 2020-09-09, 00:05:
Try an earlier V2 driver as well. The latest ones tend to be buggy.
Thanks for the reply! I thought I had followed up here but I had to use the following switches when launching the game.
-3DFX -NoPal256 -Alpha
Works without issue now! I hope this helps someone else.
Reply 6 of 8, by filipetolhuizen
Good to know. Back at the time when I finally had a chance to try this patch I wasn't using the voodoo 2 anymore, but it was still very useful as the unpatched game was incompatible with Geforce cards as well.
If you're using the -3dfx parameter and the game works now, make sure it wasn't trying to use your primary card. If it actually was and there were lock-up issues, there might be a problem with your primary card drivers.
Reply 7 of 8, by dr.zeissler
For V1 I alway use reference-drivers with glide 2.43. That works "-3DFX -NoPal256 -Alpha" but I always had issues with that that I can't remember.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
