First post, by buckeye
Just installed GOG Expendable on my W10 sys and it works great except it won't benchmark using the "go.exe" -timedemo option.
Tried copying the install to my Win98 sys and it also worked fine but again wasn't able to run the timedemo. Guess maybe GOG
broke it somehow?
Foxconn Q45M E8400 Core2 Duo 3GB DDR2 800 BFG Geforce 7950GT 512MB X-Fi Xtreme Music 500W XP SP3
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
Intel DH61CR i3 LGA-1155 8GB DDR3 EVGA 1050ti 4GB 480GB SSD 650W
Reply 1 of 3, by The Serpent Rider
I suspect they had to modify executables, because vanilla Expendable can't run on NT 6.x OS with modern hardware beyond menu screen.
Reply 2 of 3, by kjliew
Vanilla Expendable run on Win2K/XP if you patched out the CPU tests or use the command line "-nocputest". This was how I checked it out on Win2K/XP VMs, should be the same on real machine. Unfortunately, GO.EXE has bugs that it can only take 1 argument on the command-line, so we can't put together "-nocputest -timedemo". Only one of them will take effect, so it either took the timedemo mode and crashed during CPU tests or skip CPU tests and run as regular game.
So the easiest way is to patch the GO.EXE to always skip CPU tests and it can run as regular game or in benchmark timedemo mode. I guess GOG version probably patched everything out to ignore the command line together with skipping CPU tests.
Reply 3 of 3, by buckeye
No big deal, can probably use MSI afterburner to get the fps. Thanks for the comments!
