First post, by Discrete_BOB_058
I have some old games from the mid 90s, that supported Sound Blaster 16, AWE32, etc. which I would back them with my hardware. Now I want to emulate the sound quality which I would have reveoved from the mentioned cards. Are there emulators that I could use to emulate the old sound cards on mu system?
YouTube Channel:
DEADHistory Walkthroughs
PC SPECS:-
CPU: AMD Ryzen 5 1600
GPU: ZOTAC NVIDIA GeForce GTX 1050Ti OC Edition
RAM: 8GB*2 Corsair Vengeance LPX DDR4 2400MHz
Motherboard: Gigabyte Aorus B450M
PSU: Corsair VX550
Sound Card: Realtek ALC892
Reply 2 of 3, by BardBun
Getting GUS to work in DOSBox is easy, this is a DOSBox config example with C: being mounted as C:\Games\DOSBox\Games
[gus]
gus=true
gusrate=49716
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
The "ULTRASND" folder is located at "C:\Games\DOSBox\Games\ULTRASND" and should contain all the required GUS files.
"ultradir=C:\ULTRASND" because "C:" is "C:\Games\DOSBox\Games"
Reply 3 of 3, by Discrete_BOB_058
Oetker wrote on 2021-02-19, 10:54:
What do you mean by SB16 emulation, noise and MIDI bugs?
Yes. And also some early Windows games only support Sound Blaster.
BardBun wrote on 2021-02-19, 11:35:
Getting GUS to work in DOSBox is easy, this is a DOSBox config example with C: being mounted as C:\Games\DOSBox\Games […]
[gus]
gus=true
gusrate=49716
gusbase=240
gusirq=5
gusdma=3
I have used it in DOSBox but just as you mentioned it, I would want to know if DOSBox would work with a different irq,dma.
YouTube Channel:
PC SPECS:-
PSU: Corsair VX550
