First post, by Sphere478
I got windows xp sp3 installed on my tyan s1564 but have been unable to get it to detect both processors
in setup I can push the button that brings up pc type but it only gives me a option for 486 c step or something rather and standard pc. under msconfig/boot.ini/advanced it only gives options for 1 processor and in device manager it says standard pc
is there a way to add the needed option to the iso or a floppy disk? I'm told I need a option for mps as the board is believed to be non acpi
🖥Fastest socket 7 build on a 430tx chipset
🖥Dual socket 7 build
Reply 1 of 1, by Sphere478
Nevermind Figured it out. Turns out in setup when you push f7 or f5 whatever (I push all three 🤣) it brings up a box with two options. Well, or so it appears it’s actually a scroll box with many options you can press up arrow and it’s right there ready to select. All good 😀
