First post, by Zaxxon
I have a (real, non emulated) p2 200 pc with windows 98. I tried running a pure dos mode game by setting it in the properties, pc rebooted, game didn't run because of emm 366 issues, when i rebooted into windows, my autoexex and config files were empty. sure inside win 98 that is not a problem but i often run games from pure dos (by rebooting pc from scratch and having dos there), what should i do to repopulate those files with at least the most basic lines needed to run games?
Reply 5 of 11, by dr_st
First make sure they are actually gone, and have not just been copied by Win98 to different names, like CONFIG/AUTOEXEC.DOS or something like that.
It will probably be simpler if you stick to one method of running pure DOS games - either the PC always boots to pure DOS (and you have all the DOS stuff already in CONFIG/AUTOEXEC), or you run Windows by default and whenever you really need to run something in pure DOS, you use the 'Restart in MS-DOS mode' just that one time.
Using both methods interchangeably sometimes gets things mixed up, like what you described.
Reply 6 of 11, by Zaxxon
Zaxxon wrote on 2021-04-02, 07:51:
hmm seems like, as written on readme, it was not meant for win9x, and indeed it takes for granted i have a DOS folder 😒
Reply 7 of 11, by Zaxxon
dr_st wrote on 2021-04-02, 07:57:
yeah i checked for .bak or other hidden variations but nothing
this is want i wanted to do, i edited the msdos.sys and chose bootgui=0 so now it boots the pc in dos mode first and i can run games there, but as long as the autoexec ecc files are empty, i cannot run anything there 😒
Reply 9 of 11, by mothergoose729
All pure dos mode does is reboot your computer with a different auto exec. I had an issue where the game I was running wasn't easy to quit out of so I ended up in a boot loop and I couldn't get back into windows. I had to use safe mode to clear out my autoexec.
I manage all of my DOS games with scripts. They copy the autoexec and config.sys I need, and then after a reboot I have a generated start script that resets them to blank so I can boot back into windows. It takes a little time to setup but it is working really well so far.
Reply 10 of 11, by Zaxxon
mothergoose729 wrote on 2021-04-02, 15:35:
This is probably what happend to me, i went into safe mode and that probably wiped out the files.
I could do that but i'd need some basis where to start, some generic ones that are not taking for granted that i have a DOS folder in c:\
Also because i noticed that now dos games (even in windows!) won't recognize my sound card at all. The fact that is not a real sb 16 but a clone (it's a IBM all in one pc from late 99 and has an integrated sound card) probably made things worse
