Ultimate Soccer Manager 98/99
First post, by Rotterdam
Anybody please help me cause I have been trying to get this thing running on xp for a year now...
The game stops in the openingscreen. This screen is cut into two halves. Curiously the right side is on the left side and the left side is on the right side!
I have tried to use vdm but it gives the same result as the normal compability settings ax xp...
Anybody help..please!!!!
Reply 1 of 12, by Nicht Sehr Gut
Not really the right forum for this as it's a Win9x title and has nothing to do with VDMSound. Will check and see what I can find out.
Update: Not much to find out. Found "ripped" version. Tested, seems completely silent, but seems to run fine with "compatibility mode (chose "Windows 98" and "Disable Visual themes"). Did not see the video error you described. Could be a video driver compatibility issue.
Reply 3 of 12, by Rotterdam
Sorry about placing it in the wrong section and thank you for the effort you allready put into it. 😀
Is it possible it has something to do with the tft (ftf?) flat screen I have? Its a daewoo. Futher on the pc is a microstar and I have this GeForce....
I have tried the compatibilymodes but it does not have the result...
I have even tried to install windows 98 but then I did not get the monitor working anymore...
Reply 5 of 12, by Rotterdam
NVIDIA geforce3 ti 200
Is this the video driver?
I recently updated the latest software (dec 3) but again no change...
There might also be something with the pci simple communications controller. I seem to have it but I lack the software and I dont know what it is for...
Reply 6 of 12, by Snover
Your driver version can be found by going to Control Panel > Display > Settings > Advanced and is on one of those tabs. (I'm on my laptop which has an ATi card in it so I can't tell you the exact name of the tab, but I know it has the nVidia logo on it.) Chances are, if the software you say you updated was, in fact, the driver package, you should have Detonator revision 40.82.
Yes, it’s my fault.
Reply 11 of 12, by Helen_C
Hi, there. If you want download the Ultimate Soccer Manager 98/99 check out this link:
HELLO I LIKE TO POST LINKS TO GAMES ON THE INTERNET! I'M SORRY BUT I HAD PREVIOUSLY POSTED A LINK TO SOFTWARE SO THAT PEOPLE COULD ENGAGE IN COPYRIGHT INFRINGMENT! I HAVE REMOVED THE LINK AND AM VERY VERY....VERY!!! SORRY FOR MY ACTIONS!
