First post, by NarakuITA
Finally I managed to install Windows 2000, so as to have more possibilities of using the software and hardware.
I am using Windows 2000 SP4.
I have noticed that windows tries to read the floppy very often for no reason.
In fact, when I started installing programs, they crash or ask for the floppy disk.
For example I wanted to install framework 1.1, but as soon as the installation started, for some strange reason, windows started incessantly and persistently trying to read the floppy, which obviously isn't there.
Same thing, with the HP scaner 2400 program. When it almost reaches the end of the installation, incessantly and insistently try to read the floppy and then the installation crashes. In this case it gives an error. The installation is canceled. This prevents me from installing the scanner.
Why this problem? A bug?
Reply 1 of 10, by Ringding
You can disable the floppy drive in device manager.
Reply 2 of 10, by NarakuITA
Already tried. Keep looking for the floppy. The bios does not allow disabling the floppy drive.
In any case I avoid, as I still use it.
Reply 3 of 10, by Cosmic
It sounds very abnormal to me. Is there any chance you could reinstall without the floppy drive connected?
I don't know any exact registry keys to check, but I think Windows may maintain a list of places to check when it needs files during device or driver installation, and I'm wondering if somehow A:\ ended up at the beginning of that list instead of C:\WINNT or C:\WINDOWS, etc. Or maybe A:\ is in the PATH variable. I suppose you could use RegEdit to search for references to A:\.
Here's another idea:
A. If you install Windows 2000 from a local hard disk, Windows 2000 defaults to the first installed CD-ROM drive letter when you […]
A. If you install Windows 2000 from a local hard disk, Windows 2000 defaults to the first installed CD-ROM drive letter when you make any changes to your installation that require files from the installation source. This does not occur if installation was completed using a network share. This means whenever it wants to add a component you have to correct the installation location.
For example, if you install Windows 2000 from D:\2128\I386 (a local hard disk), Windows 2000 will default to E:\2128\I386 when the source files are needed (where E is the first CD-ROM drive letter).
To fix the problem perform the following:
Start the registry editor (regedit.exe)
Move to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup
Double click on SourcePath and change to the correct location. Click OK.
Now move to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
Double click on SourctPath and change to the correct drive letter, e.g. C: (it must have a I386 structure)
Close the registry editor
https://www.itprotoday.com/compute-engines/de … ion-not-correct
Rigs: Harris 286-16 [WIP] | Am386 DX-40 | i486 DX4-100 | MMX 233 | K6-III+ 600 | P!!!-S 1.3GHz | XP 3200+ 2.3GHz | Q6600 3.2GHz
Reply 4 of 10, by Ringding
NarakuITA wrote on 2022-09-13, 17:19:
The device manager has nothing to do with BIOS. And the floppy device can easily be enabled/disabled on the fly.
Reply 5 of 10, by NarakuITA
Ringding wrote on 2022-09-14, 08:42:
As just said, already tried. The bios was just additional information.
Reply 6 of 10, by Ringding
So it accesses the floppy drive when it’s disabled in device manager? This is indeed strange.
Reply 7 of 10, by NarakuITA
Cosmic wrote on 2022-09-13, 20:33:
It sounds very abnormal to me. Is there any chance you could reinstall without the floppy drive connected? […]
Nothing, the search finds nothing.
The suggestion to modify the registry was not successful, unfortunately ...
Reply 8 of 10, by NarakuITA
Ringding wrote on 2022-09-14, 11:31:
Yes, very strange and yet even if disabled, it always looks for the floppy.
I don't understand how to fix this damn problem!
Reply 10 of 10, by rmay635703
When I had this issue I would just put a disk in the drive and then got a file xyz123 not found error turned out to be a missing file from a winmodem that it kept freaking out over.
