First post, by Qbix
- DOSBox Author
When i start the game (win2k sp3) :
error reading registry and it quits.
Any idea on how to get it running ?
Qbix
Water flows down the stream
Qbix
There should be some sort of patch for it, i had it running in win2k anyway. Wouldn't go fullscreen but still worked nicely.
Have you used this patch?
patch worked!
one little drawback
game pauses when a new background song is played.
(and can I run it fullscreen ? )
Originally posted by Qbix (and can I run it fullscreen ? )
According to Harekiet, apparently not. You could try compatibility mode to force a 640x480 display.
That doesn't work in W2K (at least, not when I've tried it). So, you'll probably manually have to switch it in your CPL. (Whoo, fun!) But in any case, closing thread: RESOLVED.
Yes, it’s my fault.
