First post, by iraklis777
good morning
iam trying to setup an old pc with windows 98,
in order to play old games for win 95/98 and dos.
my setup is the following
Gigabyte GA-7S741M Socket 462 (A)
(acer model t120e branded , gibabyte 462 motherboard with sis chipset and onboard graphics which i dont need and i cant deactivate on bios)
sb live 0228
athlon xp barton 2800+
an lg ide dvd recorder
and 2 ide hard disk 40 and 120gb)
onboard lan
my problem is the following:
after finishing sb live main vxd driver installation, my next movement is to install sb16 emulation drivers for sb live.
after this , on first restart and all the other restarts or power ons , i have the following message : emm386 not installed--unable to set page frame
do we have a sollution for this problem?
thank you
Reply 1 of 2, by NT4Boy
have you tried this?
Put the following statements in your Config.sys file (if there isn't one just create one in your root folder):
Device=c:\windows\himem.sys /testmem:off
Device=c:\windows\emm386.exe ram d=64 min=0
Dos=high,umb
Reply 2 of 2, by iraklis777
thank you very much
i will try it
