First post, by JF_Sebastian
Good morning,
i am new here in the forum, so "Hello" at all. I am glad to be here!
For few weeks i have rescued an old ARTIST P133 from the electronic junk. Here some specs:
Gigabyte GA-586S
64MB EDO RAM
Intel Pentium 133Mhz
ELSA Winner 2000AVI-4
3com Etherlink 10/100PCI
Dawicontrol DC-150 RAID
I installed just4fun an DC-150 to run SATA drives and wanted to test the speed with CrystalDiskMark. Unfortunately, it crashes at startup with an information about runtime failure. Does anybody have an idea what i have to do to fix this problem?
Best regards,
JF
Boot Up or Shut Up!
________________________
Asus P/I-P55T2P4 Rev. 3.10
Asus USB/MIR Rev. 1.11
AMD-K6-III/450AFX @6x83MHz; 2.4V
4x128MB EDO RAM 60ns
MATROX Mystique MGA-1064SG-D 4MB
Diamond Monster 2 8MB
DELOCK 91620 - CF to IDE
Reply 2 of 4, by JF_Sebastian
ElectroSoldier wrote on 2023-10-26, 06:49:
I use CrystalDiskMark 2.2 on Windows 98. (CryatalDiskMark 9x)
Hello ElectroSoldier,
thanks for your reply. Meanwhile i found out where the failure comes from. Unfortunately, i had the newer version without win9x support and the file was wrong declared. Would you tell me where i can find the version you are using?
Best regards,
JF
Boot Up or Shut Up!
Reply 4 of 4, by JF_Sebastian
Thanks a lot. Benchmark works fine 😉
Boot Up or Shut Up!
