First post, by ReignerDeustcher
I'm trying to run this game in windows 10 since a while, i remember that it can be run with dgvodoo2 only in software mode (in 3d only showed white graphics) now i've tried the lastest version and it looks fine in 3d but it goes like at 1 fps... i wonder if there's a way to improve that
Reply 1 of 17, by BEEN_Nath_58
ReignerDeustcher wrote on 2023-11-12, 21:18:
How did you even start the game? It doesn't work with dgVoodoo2 here, what are your dgV2 settings
Reply 3 of 17, by BEEN_Nath_58
akula65 wrote on 2023-11-13, 16:18:
Others have posted about this game: Superbike 2000, 2001 Windows 10?
Yes I checked that page. By some terrible luck, nothing worked, even I can't get the game to change to SW mode as the OP is using
Reply 4 of 17, by ReignerDeustcher
BEEN_Nath_58 wrote on 2023-11-13, 11:07:
doesn't work, it gives ''primary surface error''
Reply 6 of 17, by BEEN_Nath_58
ReignerDeustcher wrote on 2023-11-15, 18:33:
it seems that there's not solution =(
To be fair you had better luck until now. I messaged other 3 people and none of them even got to the race...in fact if a debugger is attached to the game, I get an error with a file "data.mix". I am not sure if that's a corrupt file or such.
Reply 7 of 17, by feda
Won't work on my end either. Can start the game and watch videos but it won't go past initial loading (fast video memory access doesn't help).
Same with ddrawcompat.
Solution for using software rendering from PCGW doesn't work.
Reply 10 of 17, by BEEN_Nath_58
ReignerDeustcher wrote on 2023-11-17, 20:04:
BEEN_Nath_58 wrote on 2023-11-17, 06:49:
Op seems to be using WIndows 10. He could replace dgVoodoo2 with DDC as feda found on the dgV2 forums
yes, win 10, what the hell is DDC?
https://github.com/narzoul/DDrawCompat/releases
Reply 11 of 17, by ReignerDeustcher
BEEN_Nath_58 wrote on 2023-11-17, 20:25:
oh my gowd, IT WORKSSS, full speed, beautiful graphics
thank yooouuu 😄
Reply 12 of 17, by feda
ReignerDeustcher wrote on 2023-11-17, 22:12:
thank yooouuu 😄
By the way, you can create a file named ddrawcompat.ini in the game folder with the following options for antialiasing and anisotropy:
TextureFilter=af16x
Antialiasing=msaa4x
Reply 13 of 17, by ReignerDeustcher
feda wrote on 2023-11-18, 03:28:
By the way, you can create a file named ddrawcompat.ini in the game folder with the following options for antialiasing and aniso […]
thank yooouuu 😄
TextureFilter=af16x
Antialiasing=msaa4x
many thanks pal!
Reply 14 of 17, by gweeneth
thank yooouuu 😄
Sorry to unearth this topic but did you accomplish this on a virtual machine or on an actual 64bit Windows 10 or 11 installation? Could you please list your steps to success? Thank you.
Reply 15 of 17, by ReignerDeustcher
gweeneth wrote on 2024-03-01, 18:49:
thank yooouuu 😄
i did it in win 10 x64, after the install i just added dgvodoo like i show in the pics and ddrawcompat and the .ini
Reply 17 of 17, by ReignerDeustcher
feda wrote on 2024-04-05, 23:46:
ReignerDeustcher wrote on 2024-04-05, 20:37:
You shouldn't use those two together. Either one or the other.
but the game works fine
