Soundblaster live 5.1 windows me problem
First post, by joker8722
I can't install drivers for my soundblaster live 5.1. Sound card gets stuck on screen everytime saying new hardware found creative emu10k1 audio processor but won't continue. its been frozen on this screen for 30 minutes and every other time I tried same thing I have tried using windows 98 and nothing changes any help would be appreciated
Reply 1 of 25, by giantclam
What driver are you using?
Reply 2 of 25, by joker8722
I found an iso for the Dell version for Windows it a Dell oem model
Reply 3 of 25, by joker8722
I found an iso for the Dell version for Windows it a Dell oem model i have tried a few others i found same issue
Reply 5 of 25, by joker8722
I have already tried those same thing as what I currently used not difference
Reply 6 of 25, by joker8722
Could the sound card be damaged or in need of a capacitor replacement i was thinking of buying another one but if that's not the case and I have the same issue it would be a waste of money I dont have another pc to test it on
Reply 7 of 25, by Duffman
It might be a hardware resource conflict?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 8 of 25, by Law212
The only time I have issues with installing drivers for sound blaster is when I dont have the exact driver it likes. I recently installed a SB Live on my pentium 3 and I was using the wrong driver and it did the same freezing during installation.
Reply 9 of 25, by BEEN_Nath_58
Does the card work under dos?
Reply 10 of 25, by Law212
BEEN_Nath_58 wrote on 2023-11-29, 13:59:
Yes it does. ( I have been using a Live 5.1 card since I bought it in the 90s or early 2000s andit does work in dos
Reply 11 of 25, by joker8722
Alright I just downloaded 5 different drivers and see if any work since the one for my model wasn't
Reply 13 of 25, by joker8722
I tried the install cd and 5 different drivers 3 of which people say work with the model i have tried to do a full re install with no gpu or anything else just sound card drivers no dice just freezes and has an error in driver menu saying code 11
Reply 14 of 25, by joker8722
Just bought another of the exact same model that said cleaned and tested so if it doesn't work it won't work on my system if it works then there's a problem with mine and I have something to go off
Reply 15 of 25, by BEEN_Nath_58
joker8722 wrote on 2023-11-30, 02:18:
MS doesn't even have a detail on code 11 lmao
Reply 16 of 25, by Duffman
I still think it's a hardware resource conflict.
CPU: Ryzen 9 5950X
Reply 17 of 25, by giantclam
Duffman wrote on 2023-11-30, 06:14:
We dunno what mainboard it is/what other cards are present ; all speculation valid =)
Reply 18 of 25, by joker8722
It a slot 1 440bx motherboard with 550 mhz pentium 3 and ati rage 128 pro gpu
Could be 440zx
Reply 19 of 25, by giantclam
Does it have onboard audio? Exact brand/model of mainboard?
