First post, by BEEN_Nath_58
MiG Alley 1.23 patch doesn't work on 64-bit OS because it uses a DOS-based file tt2.exe. Is there any way to install the patch without resorting to copying the files from a VM to the main OS? Like a manual patch or a pre-patched set of files?
