First post, by philthethrill
I ordered Madeline’s Thinking Games from eBay. When I start the game, it says “Video not available, cannot find ‘vids:arbc’ decompressor.” Any suggestions?
Reply 1 of 5, by BEEN_Nath_58
philthethrill wrote on 2024-03-19, 00:53:
Where are you trying to run the game? And which OS did you install it in?
Reply 2 of 5, by crazyc
I don't if you were using winevdm to run it but when I tried it I found the same problem. I've implemented support for loading win16 codecs here, https://github.com/otya128/winevdm/pull/1388, which makes this work.
Reply 3 of 5, by BEEN_Nath_58
crazyc wrote on 2024-03-21, 01:06:
how do I download it from appveyor? Also the deluxe edition of the game doesn't see the OS as supported
Reply 4 of 5, by crazyc
BEEN_Nath_58 wrote on 2024-03-21, 05:37:
https://ci.appveyor.com/project/otya128/winev … 71et7/artifacts
One that I tested didn't have any problem installing.
Reply 5 of 5, by BEEN_Nath_58
crazyc wrote on 2024-03-21, 13:55:
The game works now. One problem is the game stops sending any messages if I don't Windows-key out of the game
