First post, by Mike 01Hawk
- Member
Those that have the real hardware and that also mess around with DOSBOX.
Dell Optiplex Gxpro: Built solely so I could re-live my SB16 days properly with newly acquired sound pieces: MT-32, SCB-55, and DB50xg 😀
we don't ?
Water flows down the stream
So all these peeps using DOSBOX, they're only getting SB quality music? If so... 🙁
DosBox uses whetever midi device you have defined to Windows. I have my SCC-1 defined as my midi device so it uses my sound canvas. It also still uses my MT-32 that I have connected to the SCC-1
wrote:So all these peeps using DOSBOX, they're only getting SB quality music? If so... 🙁
Didn't there used to be an old CVS or branch of code that had CanadaCow's MT-32 emulation in the build?
At the very worst you can use MUNT and point DOSbox to it... assuming you have the MT-32 ROM dumps.
