Reply 880 of 1741, by RaVeN-05
- Oldbie
If you press alt+m or alt+x you should see fps, but game will go into timedemo mode, much faster
Everything fixed:
Could someone with an actual Verite board comment on the audio sync. I think the video is lagging here.
https://www.youtube.com/@sharangadayananda
RaVeN-05 wrote on 2024-04-02, 12:13:If you press alt+m or alt+x you should see fps, but game will go into timedemo mode, much faster
I can't. Keyboard interaction hasn't been implemented yet.
What kind of framerates do you get on your V2200/2100?
@robertmo, will investigate framerate issues with other games tomorrow.
I guess I can borrow the io code from glidos or at least parts of it. .
it looks random helmet generator when turning exists also on real hardware 😉
There's some other game, F1 I think, which has a similar issue with some textures.
robertmo3 wrote on 2024-04-02, 13:05:it looks random helmet generator when turning exists also on real hardware 😉
Yes. That had me worried at one point.
Frame sync is also a big problem.
Rr. Exe, the rendition ready app terminates before everything renders. Bits of it render (first 1/3) with sync disabled. If not just a white screen., early frames. I think by studying this app I can get synchronisation working.
Video is slower (unsynced)
In alt+x a performance test mode I get 40 as minimum and 80 as maximum fps in intro.
55 I would like to say is average.
Game is limited to 30 fps in normal mode
Thanks @Raven-05.
Tomorrow the frame sync., but first the tranya.
other "preserved" game features are:
- pulsating to square cars wheels in the distance,
- 2d textures "fireworks" (visible on a video of original hardware as dirty yellow horizontal lines)
thing i didn't noticed on video of original hardware is:
- gray road bank sometimes blinks
Oh is the icr2 exe also called cart. Exe? It might be relevant if I need to feature mask rready special case handlers. I'm hoping it won't come to that.
Rendition. Cfg settings on a per app level will be migrating to the dosbox Cfg file, so I'll probably need to know all the exe names.
robertmo3 wrote on 2024-04-02, 13:52:thing i didn't noticed on video of original hardware is:
SODA Offroad has similar issues. Might be a bug with rready.
Are there any v1000 videos of ICR2? I'm relying on @raven-05vs videos. He has a V1000.
This video I think is on V1000.
IndyCar. Exe on the original version.
sharangad wrote on 2024-04-02, 13:57:Oh is the icr2 exe also called cart. Exe? It might be relevant if I need to feature mask rready special case handlers. I'm hoping it won't come to that.
They re-released IndyCar Racing II as CART Racing. They don't seem very different and you can turn one game into the other by moving over the menu and cars.
In your video this morning the sound is playing normal speed. Video was definitely slower than it should be.
I have both the Rendition indycar.exe and cart.exe if you need them.
Thanks. Will need to test IndyCar. Exe as well, just to be sure everything works.
