Reply 1080 of 1624, by sharangad
RaVeN-05 wrote on 2024-04-21, 12:28:
Buffer dims 640x480 stride 81 and linebytes 1280
Buffer dims 800x600 stride 81 and linebytes 1280
Buffer dims 1024x768 stride 81 and linebytes 1280
Buffer dims 1280x1024 stride 81 and linebytes 1280
That can't be right.
https://www.youtube.com/@sharangadayananda
Reply 1081 of 1624, by sharangad
Could you try this and see if it's any different:
https://1drv.ms/u/s!As-dKk-N73dSmG7UyjpNtIta3s3g?e=5ELl0L
MD5: e1cdd96b97729c5010605d7ab0abd4c8
I think the original buffer was being cached. This time around the session is recreated before creating the buffer.
Reply 1082 of 1624, by sharangad
RR.exe is almost 100%. The last part doesn't render correctly, the final logo.
Your source code dump explains how to handle V_FIFO_SYNC_AND_RESPOND.
Also could you post a video of the Michigan new track (two laps) if you've got the time and willpower to spare. This is the rendition enhanced track.
Reply 1084 of 1624, by sharangad
RaVeN-05 wrote on 2024-04-21, 15:53:
linebytes gives me same results
michigan video https://fex.net/s/mao03lx
The linebytes result is weird.
How come your ICR2 videos have beautiful yet subtle fog and mine don't?
Reply 1085 of 1624, by sharangad
[Alt]+[X] Turbo mode works now, but the framerates are disappointing and the sky is purple.
https://youtu.be/PQ2F3MAcfuQ
Reply 1086 of 1624, by RaVeN-05
sharangad wrote on 2024-04-21, 16:13:
good question =) .
framerate is limited by dosbox itself, i mean not exactly framerate but inability to use high CPU clocks, i think dosbox can't go at 350mhz pII like mine? that's why i told way back to use dosbox-stages , as its probably only one dosbox fork managed to emulate higher CPU rates .
sky is purple , yes something odd , keep in mind ALT+X disables AA, disable mirrors, and turn on sky optimization which cutoff top part of it, and uses solid color instead, probably one that called by ClearColor function?
Please fix me if you know more, its way how i see it.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 1087 of 1624, by sharangad
RaVeN-05 wrote on 2024-04-22, 12:08:
good question =) . […]
good question =) .
The dosbox staging guys kicked up a fuss, I might port it to that as well. I think I have a solution for the licensing issue.
The DosClient which renders the games will be GPL 2.0, for which I, as the author grant a license exception to use a closed source library. DosClient talks to Dosbox via named pipe via a complex protocol, which is OK because I it's GPL 2.0. I think that's how the other closed sourced wrappers did it.
I'll port it to dosbox staging as well. Shouldn't be difficult now.
Reply 1088 of 1624, by sharangad
good question =) .
Your post is spot on. I should be able to port it to dosbox staging without much of a hassle. The rights holders kicked up an almight fuss, but I'm sure making DosClient GPL 2.0 resolves the issue.
They were also extremely unhelpful.
Reply 1089 of 1624, by robertmo3
dosbox's speed depends only on the speed of your computer's cpu speed. nothing is limiting dosbox.
if you want more speed you can use qemu which sends cpu messages directly to your real cpu, hence is many times faster
of course no cpu/emulator will speed up anything if game is limited to 30 fps 😉
Reply 1090 of 1624, by sharangad
robertmo3 wrote on 2024-04-22, 14:30:
In [Alt+X] mode the framerate should be uncapped. if you check out this video:
https://www.youtube.com/watch?v=CwQSQ63W50c&t=639s
Alt+X uncaps the framerate, though I'm not entirely sure how the board is running at 190 fps.
Reply 1091 of 1624, by sharangad
Got the rendering ported to dosbox staging. Get this:
Reply 1092 of 1624, by RaVeN-05
Please do tests wisely, you will find it surprising that dosbox-staging has more cpu speed emulation comparing to dosbox original.
Try Chasm the rift or Quake or desperabis all those very cpu demand games and you will see that dosbox limited
Reply 1093 of 1624, by sharangad
RaVeN-05 wrote on 2024-04-22, 15:23:
I won't do anymore speed tests until I have dosbox-staging compatibility at 100%. I generally find staging quicker.
Reply 1094 of 1624, by RaVeN-05
https://www.dosbox.com/wiki/Performance
used Note: Based on Speed Test 1.14
in dosbox 105% "û This computer 332117 parrots, 123.1 XT"
vs
dosbox staging 105% "û This computer 392241 parrots, 145.4 XT"
ok ok
Reply 1095 of 1624, by sharangad
If you've got power can you run good ole FIFO again:
https://1drv.ms/u/s!As-dKk-N73dSmG__kqJd7gQTP3Ey?e=cUhUmu
MD5: a0287c185d57c50079b5185d66fa37bc
Attach the FIFO.txt file here. What I really need is the Int21h call results at the end (EDI on entry and pre-exit):
AllocDosMem returned 1
SWI Before: (Int 21h)(Call 1) AX B101, BX 58B8, CX 3246, DX 00A7, ES 01D0, EDI 00000000, FLAGS 0246
SWI After: (2) AX B100, BX 58B8, CX 3246, DX 00A7, ES 01D0, EDI 00000000, DS 0000, SI 0000, EDI 00000000, SP 0000, FLAGS 0212
Int 21h succeeded
FreeDosMem returned 1
I think the secret of vQuake support is in EDI, which should have the protected mode entry point for such calls. In the case of dosbox-rendition, this is set to NULL (0).
Reply 1096 of 1624, by sharangad
RaVeN-05 wrote on 2024-04-22, 15:47:
https://www.dosbox.com/wiki/Performance […]
vs
ok ok
Now that's a lot of parrots! It's quite a bit faster.
Reply 1097 of 1624, by sharangad
After disabling logging, the performance mode framerate varies between 40-70 fps with occasional audio stutters.
This is with bog standard Dosbox, not elite dosbox-staging.
Reply 1099 of 1624, by sharangad
robertmo3 wrote on 2024-04-22, 17:46:
just wondering as latest dosbox staging is 64-bit only
are you using 64-bit rready or
using 32bit rready with older 32-bit dosbox staging
I built a 32 bit version from source. My code snapshot is from last year, so it still supports 32 bit.
It should still work with 64 bit Dosbox, since everything goes down a pipe. Dosclient is 32 bit.
