As a quick performance test and for some early feedback (for ICR2 only) an alpha build (an actual alpha not like the regular RReady Alpha):
Only for ICR2 (still extremely buggy).
[EDIT2]
Smaller pipe slow but stable[Not recommended):
RReady Alpha^3 (20240426)
https://1drv.ms/u/s!As-dKk-N73dSmHF4CMlMCmq6Nggx?e=0UpUZq
(Recommended) Large pipe buffer, randomly unstable (but not that unstable 😀. My videos use a larger buffer):
RReady Alpha^3 (20240426) 003.
https://1drv.ms/u/s!As-dKk-N73dSmHSbI_Oqe9qKW0qP?e=4kNO9T
MD5: 31b7f5b1e3333d48084f1d7123fa6ea8
[/EDIT2}
MD5: cab8882533e459fe1e8d8fd5fadff4df
Dosbox Alpha^3 (20240426)
https://1drv.ms/u/s!As-dKk-N73dSmHIlbDF7JglTLDO4?e=nnboFN
MD5: c860b3dae811542cd65d860cd8c08928
[EDIT] You'll need a temp folder in C: drive.
Dosbox-Rendition and DosClient source is available here https://sourceforge.net/projects/dosbox-rendition/.
Dosclient and dosbox-Rendition are GPL 2.0 and Dosclient has a license exception to support closed source system libraries like the Rendition ones. A compatible V1000 BIOS (VBI files) has been supplied. Other BIOSs will not work. Certain parameters have to be configured for each BIOS and this release has hard coded parameters for the supplied BIOS.
Download and unzip the dosbox package and and add dosbox as an application to RLauncher. Always launch Dosbox from RLauncher as this will update dosclient.
DO NOT RUN MORE THAN ONE Speedy3D APP IN SEQUENCE. Close Dosbox and relaunch it from RLauncher. This means no cartfast,bat or cartsafe.bat run cart.exe or indycar.exe directly. RR.exe still has issues.
This is only for ICR2 and it will still be buggy. You can try running other Speedy3D apps but they're not supported in this release. NR1999R has regressed and will not work correctly here.
This release is to gauge whether the CPU requirements are too high. I *think* you'll need at least a quad core and a discrete gpu.
Hopefully during testing nothing disgusting will happen. I've shrunk the named pipe buffer down, so the CPU load will be higher, but more stable.
https://www.youtube.com/@sharangadayananda
