Reply 1300 of 1632, by sharangad
- Oldbie
Something more sinister.
Can't fix it tonight.
https://www.youtube.com/@sharangadayananda
And a lightning strike took out the power. Pah.
the first log was from cart racing
I think this is the fallout from my enhanced texture loading code.
Will sort it out tomorrow.
robertmo3 wrote on 2024-05-05, 14:12:BEEN_Nath_58 wrote on 2024-05-05, 13:37:Intel HD Graphics compatibility with Pentium G2020 (Ivy Bridge) […]
MDK: crash
Soda Off-Road Racing: crash
Grand Prix Legends: major graphical issues
Sub Culture: works
Heavy Gear: works
Die by the Sword: works
Team Apache: works
Formula 1: works
Hexen 2: works
Quake 2: works
Interstate 76: works
MechWarrior 2 Titanium Edition: works
Myth The Fallen Lords: worksyou missed Monster Truck Madness 2 😉
Went back to test that: works
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EauK7zfq … gSd5FQ?e=MCyiSX
MD5: f19bebcce2ae5983222a64b512e82dce
Should correct the performance regression. It was a reusable 16 MB buffer which was being recreated. It used to be fixed, but during testing I made it dynamically allocated.
with 001 it was 4fps in nascar, now it is 10fps
but in 04.30 it was 30fps 😉
cart racing is 22fps all the time
team apach works on my integrated too
(hit esc 3 times when starting to skip movies)
(same menu corruption on both cards)
robertmo3 wrote on 2024-05-05, 17:37:with 001 it was 4fps in nascar, now it is 10fps
but in 04.30 it was 30fps 😉cart racing is 22fps all the time
04.30 had fast mem writes speeds, but broke fifo mode.
29,28 also had 30fps
26 had 20-30fps
Also I haven't given much love to nascar. Maybe it's time to start.
dosclient is above normal priority again
robertmo3 wrote on 2024-05-05, 19:15:dosclient is above normal priority again
It is yes. I reverted a bunch of changes and I think that got rolled back.
Is it impacting performance?
yes whiplash intro in dma=0 has jerky sound
robertmo3 wrote on 2024-05-05, 19:32:yes whiplash intro in dma=0 has jerky sound
Has anything else regressed, at least as far as you can tell?
You're quite lucky, I only get 4 fps in Nacar. I don't test it very much.
higher priority for dosclient was making jerky sound on 2 cores
for the sound to be good: dosbox had to be higher, dosclient normal
both on normal was jerky sound too
on win8.1
win11 required dosbox to be highest
sharangad wrote on 2024-05-05, 19:58:You're quite lucky, I only get 4 fps in Nacar. I don't test it very much.
it's not luck, its a real cpu (intel), stay away from amd
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EQah15KD … _leznw?e=YtEjd6
MD5: 1e445244e60ddcc8c47c25f86eee8401
robertmo3 wrote on 2024-05-05, 20:24:sharangad wrote on 2024-05-05, 19:58:You're quite lucky, I only get 4 fps in Nacar. I don't test it very much.
I have noticed your quad core runs better than my Ryzen in quad mode.
Ivy Bridge is cool. I still have my old Sandy Bridge machine. But the newer Intels use ridiculous amounts of power.
