Reply 1620 of 1777, by sharangad
sharangad wrote on 2024-05-19, 16:41:
robertmo3 wrote on 2024-05-19, 14:38:
here
When I tested this, I renamed tomb. Exe to tombren.exe.
I figured you'd done the same thing.
Sorry @robertmo3, I should've realised this sooner without wasting your time.
https://www.youtube.com/@sharangadayananda
Reply 1622 of 1777, by sharangad
ICR2 fixes:
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EdWVCTN0 … KR7J3Q?e=xzcVF5
MD5: 765b5be595c42e192750a23e7b69a1fe
-Whiplash performance problems are still there.
- Tomb Raider videos may have issues playing back (especially new game/Croft Manor).
Reply 1623 of 1777, by sharangad
Tomb Raider 1 pre-rendered custscenes should be 100%:
https://1drv.ms/u/c/5277ef8d4f2a9dcf/ET7iS4iS … oTP1Aw?e=iTu4Fq
MD5: 3c7a2cf6601986dad2cfe2c06db6df5b
ICR 2 pit crew might render incorrectly occasionally.
Reply 1624 of 1777, by sharangad
Could someone with a Rendition board and a copy of Indy Car Racing 2/Cart Racing 2 try replacing the effecs.dat file in the game's effects folder with the attched one and see if smoke and dust effects work?
Thanks!
[EDIT] Also is the pre-existing file 36 KB or 50 KB?
Reply 1625 of 1777, by sharangad
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EZkPpHp7 … vFcSXQ?e=JQ5HX7
MD5: 399a3d386dc7e042a89bb155790315a7
All texturing and fogging issues with ICR2 should be fixed. The upscaled mirrors may have issues. No other games have been properly tested.
Once I fix the random glitch with the mirrors, this game should be 100%.
Up next CPU load saturation stability fixes.
Reply 1627 of 1777, by sharangad
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EbNl5dqw … DnWb9Q?e=1RS6MH
MD5: dd1304534fd842ae071305465ce46dec
- ICR Central Mirror can be enabled by adding mirror=1 to rendition.cfg
- Tomb Raider texture corruption fixed.
- Whiplash performance problems fixed.
- Nascar 2 performance regression.
Reply 1628 of 1777, by gplaps
Hi Sharangad,
Thanks for sharing the updated build in response to the Youtube comment I left. I spend some time this afternoon installing and getting it working. I was able to get it playable but having a problem with the menus/cockpit being scrambled. I believe this might be because I am on a 21:9 monitor? I tried various configuration settings, including trying to force it to run at 16:9 but the output was either squashed or had corruption like this.
Menus:
Is the only option right now for fullscreen or is there a windowed mode as well? I will keep testing with it. The framerate was nice and stable when it was working!
EDIT: I have figured out the issue, I had only installed the "Rendition Patch" on a DOS version of ICR2, however there are additional changes in a full Rendition version. I have reinstalled the game from the CD with the rendition version and the menus/cockpit appear normal now!
Reply 1629 of 1777, by sharangad
gplaps wrote on 2024-05-24, 18:26:
Hi Sharangad, […]
Hi Sharangad,
Menus:
Excellent! How well does it run? Is it stable.
Reply 1630 of 1777, by sharangad
Hi Sharangad, […]
Hi Sharangad,
Menus:
You'll have to swap out the 50 kb effects.dat file for the 36 lb version from the dos version in the effects folder for smoke and dust effects.
Reply 1631 of 1777, by sharangad
The Verité microcode file spd3d.uc is responsible for this. I guess rready /dosbox-rendition is coded for the uc file from the full game.
Reply 1633 of 1777, by gplaps
Hi Sharangad,
The issue I was having was caused by using the v2 "SPD3D.UC" found on a few different sites including racesimcentral: https://racesimcentral.net/indycar-racing-ii/?sim=downloads
I've attached that version of the file (71kb):
V2SPD3D.zip
Reverting to the 56kb version of the "SPD3D.UC" packaged with ICR2 Rendition resolves the menus/corrupted cockpit. I am unsure what the "V2 Update" file was meant to do, so perhaps it is not necessary.
I was able to play with the RReady Wrapper and ICR2 for a few hours, and recorded a short video of part of a race I was having:
https://youtu.be/ApCxuHBKY_8
Overall the game plays fairly well with the standard carset and tracks, however I did notice some issues. I've written them below in no particular order. Some of these issues might not necessarily be a part of the wrapper, but perhaps differences in this version of Indycar Racing II, however I will note them nontheless.
I have been playing with the following parameters:
set SPEEDY3D_DMA=1
set SPEEDY3D_MEMSIZE=8 (I have tried this at higher numbers too, im not sure if they would do anything)?
  • When running 32 cars (with 32 cars visible front and back) at the "New" Michigan track, the graphics will sometimes corrupt and artifact when many cars are in view and appear to 'freeze'. It also happens frequently when going into replay mode near the start of a race. The sound/audio is still playing in the background, and you can still control the game. Sometimes the display will return to normal, sometimes it will crash.
  • The helmets of the other cars randomly change color
  • There are some single pixel transparent lines of the cockpit
  • Some keyboard controls no longer function as expected. The 'W' key should show or disable the transparent 'windscreen', but it does nothing. The "F10" key should show an external view of the car when driving but does not function. The '+' and '-' keys should increase or decrease the front rollbar (indicated by the small "f" bar on the top right of the dashboard). Both of these keys do not function, however by holding alt and the '+' key it is able to make the bar go up, but alt and "-" does not decrease the bar. The same is true for the rear anti rollbar, the bracket keys typically control this, but they only function when also holding 'alt'.
  • Most addon tracks/carsets do not work and either show "Insuficient memory" for tracks, or "Not a Valid Carset" for carsets. I was able to get a few more basic carsets to load (potentially ones with standard sized texture files). For these addon carsets which feature a more complex 3d shape, the FPS in the game is very low when running with them (10 - 15fps). I have attached one example of these kinds of carsets here in case you would like to experiment with it.
I will keep experimenting with this version of the game. It is very very neat to see it at a higher resolution after playing with it at 640x480 for so many years. Thank you again!!
Reply 1634 of 1777, by sharangad
gplaps wrote on 2024-05-25, 11:09:
V2SPD3D.zip
This is a version of the Verité microcode for running ICR2 on a V2000 board. The game by default in pure DOS mode will not run on a V2000.
set SPEEDY3D_DMA=1
This tells the static linked Speedy3D libraries built into the game how much RAM to use. The readme says this can be increased to 4MB from 2MB (I wasn't even aware there were 2 MB boards). But it might do nothing beyond 4MB.
[*] When running 32 cars (with 32 cars visible front and back) at the "New" Michigan track, the graphics will sometimes corrupt and artifact when many cars are in view and appear to 'freeze'. It also happens frequently when going into replay mode near the start of a race. The sound/audio is still playing in the background, and you
This is the random instability that I might've mentioned. A spike in the CPU use causes this. It usually crashes. It will be fixed, just as soon I figure out how.
[*] The helmets of the other cars randomly change color
This is a 'feature' of the game (when turning, I believe)
[*] There are some single pixel transparent lines of the cockpit
I know what causes this and I'll try and fix it. It's not a priority at the moment.
[*] Some keyboard controls no longer function as expected. The 'W' key should show or disable the transparent 'windscreen', but it does nothing. The "F10" key should show an external view of the car when driving but does not function. The '+' and '-' keys should increase or decrease the front rollbar (indicated by the small "f" bar on the top right of the dashboard). Both of these keys do not function, however by holding alt and the '+' key it is able to make the bar go up, but alt and "-" does not decrease the bar. The same is true for the rear anti rollbar, the bracket keys typically control this, but they only function when also holding 'alt'.
The keyboard shortcuts in the Rendition version use [ALT]. For instance [ALT+M] toggles mirror detail. In your video you're running at medium (low really). [ALT+W] Cosmetic weather, [ALT+R}] Show framerate, [ALT+X] high framerate demo mode. There should be a readme on the CD for the Rendition version with a full list.
[*] Most addon tracks/carsets do not work and either show "Insuficient memory" for tracks, or "Not a Valid Carset" for carsets. I was able to get a few more basic carsets to load (potentially ones with standard sized texture files). For these addon carsets which feature a more complex 3d shape, the FPS in the game is very low when running with them (10 - 15fps). I have attached one example of these kinds of carsets here in case you would like to experiment with it.
This might be because memory management for larger textures sizes is messed up. How do you load a carset? If I can load your carset maybe I can fix it.
You're welcome and thanks for trying it out.
Reply 1635 of 1777, by gplaps
Hi Sharangad!
sharangad wrote on 2024-05-25, 11:48:
I am familiar with the visual of how the helmets look when turning, however the colors of the helmets themselves change (a driver's might be red in one view, and suddenly it is green in another) and are sometimes the wrong color or grey. The helmets themselves use a different texture format than the regular cars do, which might be a reason why. When looking at screenshots/videos from racesimcentral's testing I can see that that cars seem to have the correct helmet colors, but for the default carset using the wrapper the helmets always appear as grey.
Screen cap from RSC's video of the intro:
What it looks like for me in the intro:
[/quote]
The new keyboard commands specific to the Rendition version work, the keyboard commands I am talking about (such as 'F10' for external driving view) are commands from the original game. Some commands work fine, such as "D" to change the dashboard display. But others don't work.
[/quote]
Carsets can be loaded by extracting the zipped folder in the "Cars" directory. And within the main menu of the game with in the 'Driver Info' page, you can change carsets using the 'carset' option. I have attached here an example of one which does not work at all.
lola1995.rar
Thanks again!
Reply 1636 of 1777, by sharangad
gplaps wrote on 2024-05-25, 12:10:
Hi Sharangad! […]
Hi Sharangad!
[/quote]
lola1995.rar
Thanks again!
[/quote]
If you look at the intro running on a V2000 board here:
https://www.youtube.com/live/CwQSQ63W50c?si=Oyadeca1x4MEvFDZ
You'll notice the helmets change colour.
Reply 1637 of 1777, by sharangad
I didn't see a carset there, but when I get some time I'll see if I can find it.
Reply 1638 of 1777, by sharangad
F10 not working is a bug in the wrapper. I don't think I tested f keys.
Reply 1639 of 1777, by sharangad
I think the monochrome helmets can be fixed by renaming defaults.ini (or. cfg) to something else and letting the game recreate it.
You do need 95 cars in the cars folders as, well as 4bit.
