First post, by shorty
Hi!
ok, on my windows xp machine i copied the zmbv.dll to my system32 directory so i thought it can be installed like on every other windows xp system with right click on the inf file but there is a window that tells me that it fails -so i give it a try with the codecs from ->http://samples.mplayerhq.hu/V-codecs/ZMBV/ -> same s*** like the other codec ... what did i wrong - today, on another xp this works perfectly ...
anybody an idea?
    6.48 KiB
Reply 2 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It can't capture GM since the midi music isn't played by Dosbox but the systems midi device, you need to capture that with another program
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
