First post, by lucasdaytona
Hello to everyone, I was doing my daily search on ebay for cool stuff, and then this apperead to me:
http://www.ebay.com/itm/390097661414?ssPageNa … 49#ht_500wt_970
I asked the seller about more info, and he sent me an email:
me:
Hello, this card uses a ISA bus? do you have a FCC ID or a model?
Thank you!
regards,
Lucas
him:
Gee, I've had a lot of interest in this card lately. What's going on? I think it is an ISA bus card, but I am not sure. Can you help me to identify it? I could not find an FCC number, but there are two labels with numbers on the back. One is M02101030000 and the other is 071671 with a bar code. It also has the copyright date of 1991 on it. C5081 is the model number and will yield a few returns from Google but it also has S5081 on the back. I hope this helps,
Stan
Then I bought the card, at least, will be a beautiful card to have in my new turbo XT motherboard (a friend gave it to me). I want to know if someone here have seen or gotten this card.
Thank you!
Regards,
Lucas
    103.87 KiB
Reply 1 of 10, by Jolaes76
I think this one will be:
ONLINE COMPUTER SYS. INC 8 BIT DSP AUDIO BOARD PULLED FROM AT&T 6386 /25 WGS
according to
http://www.ambry.com/C5081.html
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 2 of 10, by Ailicec
In looking around, it seemed like there were a bunch of copies of the ebay text. I wonder if various aggregators are copying ebay buy it now items, marking up a crazy price, then if you buy it from them, they go and buy it from ebay and pocket the difference. Another theory is this ebay seller just copied HIS text from one of those other sites. Either way, there doesn't seem to be much real info.
My guess is that it is a special purpose DSP board that you can program with various processing.. if you knew how to interface to it. I knew a guy who used such a board for room reverb processing on an ancient 486. Back then, the DSP chips would blow away regular CPUs for audio processing.
Its hard to say due to the as-usual awful Ebay photos.. seriously, if these guys would take a decent picture, and describe the item well, they'd make a lot more money.
Let us know when you get it. Find the most expensive looking chip and thats the best teller 😀 The big socketed one may be a CPLD, if it is that doens't tell much. I'd look for a TI DSP chip on there. Unfortunately, I doubt this thing is set up as a SB compatible or anything else you can easily use.
Reply 3 of 10, by sklawz
hi
in the 90s i worked with some cards made by
dialogic. at a guess this card is similar, yet
probably even older, in that it was designed
for a specific purpose other than audio playback
and more likely something to do with
telecommunications.
bye
Reply 5 of 10, by GXL750
The computer that card shipped in has some mention in an old late 1980s issue of Network World Magazine. They advertised said computer as being notable for having the ability to answer a phone.
http://books.google.com/books?id=JxMEAAAAMBAJ … 5%20WGS&f=false
Reply 6 of 10, by lucasdaytona
Thanks to everyone to the replies, but I do not think that my card is the one from the google books, take a look in this auction from ebay: http://www.ebay.com/itm/AT-T-6386-25-WGS-Voic … ht_14195wt_1042
for me, this computer have these answering phones cards. I bet this card is another type...
but thank you, great info!
Reply 7 of 10, by keropi
I can bet you that this card in the end will be a paperweight to you. Not only it is suspiciously looking like a telecoms card but it will not even function as a sound card.
edit: I just saw the original auction too, this won't be of any use to your XT machine....
Reply 10 of 10, by lucasdaytona
the board is finally here, two notable chips:
one pretty fast (40MHz) 68 pin TMS320C25FNL, and one Bios looking PCM54HPJ 28 pin... 4 RCA jacks, labeled IN1,IN2,OUT,SPKR.
Full size ISA card.
Any clues? Any software to discover the card?
thanks!
