ATX 2.x to ATX 1.1 mod?
First post, by PoulpSquad
Hello
So today my old Tagan PSU died peacefully after years of duty (I don't know if the damn thing took the motherboard with it, I got no way to check it out, it was the only one I had).
So my objective is to modify a Thermaltake PSU I got no use for.
Sure enough, it's missing the -5V white wire, but I was wondering if it would be possible to bring that from some place else in the PC and add a wire to the ATX connector.
Any thoughts on this?
Cheers
Reply 1 of 7, by 5u3
Tagan PSUs seem to be made of suck. I never saw one that lasted more than a couple of years.
Do you have one of the rare ISA cards that need -5V?
Reply 2 of 7, by robertmo
My Tagan TG400-U33 is already 6 years old. Very silent, no problems so far.
Reply 3 of 7, by PoulpSquad
I don't think so, the only ISA stuff I got is a SB Gold and an Audician 32 Plus
(for the record I got an Asus P2B-F and an Asus P3V4X)
Reply 4 of 7, by 5u3
The lack of a -5V rail is not going to be a problem - at least for the hardware you mentioned.
Cards which need -5V tend to be a bit older - best known among these are the Soundblaster 2.0 and the Roland LAPC-I. If you don't plan on getting one of these, you can ignore the missing voltage rail.
Reply 5 of 7, by PoulpSquad
Thanks for your input. Chronology so far:
- Old Tagan PSU on Asus P3C mobo: unstable, would work most of the time, usually stalled on first attempt to turn machine on, would work on second attempt. Once I noticed all voltages in hardware monitor in BIOS go from nominal values to 0.0 marked in red... after a couple of days, machine turns on but no video. Replacing the Pentium II 400 with a Pentium III 1000 gets PC a little further half of the time, to memory POST, where it would always freeze on memory count. Other half of the time PC would turn off, LCD monitor detects signal, but nothing gets displayed.
- Build a new box, this time with an Asus P2B-F. Plug old Tagan PSU in, PC turns on, fans work, no video.
- Found an ATX 2.2 PSU (a Thermaltake Toughpower W0106 with cable management, 700W) and tried it on an old P4 HP mobo. Can't find the 4 pins cable that plugs in the auxiliary power connector of the mobo, so I used an adapter Molex -> 4 pins. PC turns on, fans work, no video (kinda expected that, without proper +12V 4 pins).
- Plugs ATX 2.2 PSU in old P3C motherboard. PC turns for a couple of seconds, fans work, but then shuts down. Couldn't see any video.
- Plugs ATX 2.2 PSU in old P2B-F. *Nothing* happens.
- Plugs ATX 2.2 back in old P3C. *Nothing* happens...
- Plugs it back to the P4 HP mobo. *Nothing* happens... starting to think I managed to kill 3 motherboards and 2 PSUs... getting good at killing stuff with age 😒
Plans for today:
- Will rip PSU from a PC I built for my girlfriend. Some Thermaltake Toughpower 1200W that I know for a fact is working (it's running as I write this). Will try it on the HP P4 mobo first, (this time with proper +12V 4 pins cable) then on the P3C, and then on the P2B-F. She's gonna be happy when I manage to kill her PC also. Expecting this to be my last day in this world 😵
- Will get a Tagan (same model as the one that died) for cheap, just to sort out what is working and what is dead.
Those are my tribulations so far. Sorry for the wall of text... I'm getting pretty discouraged, it's a lot of trouble for something that could be done reasonably well with an emulator on a modern PC... if you guys have any ideas, I'd be eternally in your debt if you could share them 😊
*Update*
Tried with the 1200W PSU, all motherboards run without a hitch. Power management flips out because of the missing -5V, but nothing is borked motherboard-wise... gonna check out the 750W PSU... if it works my girlfriend is gonna get a PSU "update" xD
Now the Tagan works fine with the P2B-F... I'm going crazy with this stuff...
I don't know if I should discard it before it really dies and use the 1200W PSU or if I should keep it... remembers me of 2001 a space odyssey... but HAL wasn't half as mean as this PC xD
Reply 6 of 7, by bristlehog
I used a pretty new Corsair 430CX-V2 with an ASUS P3B-F without any problems... except for lack of -5V rail, but I set up the BIOS power management to ignore -5V value so that I get no errors upon turning the power on.
Hardware comparisons and game system requirements: https://technical.city
Reply 7 of 7, by PoulpSquad
Yes, you are right, I noticed this today. That's another thing learnt, -5V is used for ISA (and not even all ISA cards use that but a couple of them, seemingly pretty rare).
At least everything is working (so far), so I'm a happy panda. But on the other hand, I don't know why it didn't work 24 hours ago, so I'm a happy -but perplexed- panda...
