PCEm. Another PC emulator.
Reply 360 of 1046, by raidenii
First of all, thanks so much Sarah for developing such an awesome emulator for old computers.
Just wondering, anyone tried to use EMM386 with WfW 3.11? I used memmaker to optimize the memory usage, which loads EMM386 in config.sys, but after reboot Windows cannot start and prompts it cannot set an upper memory block at segment B000.
Thanks.
Reply 361 of 1046, by HalfMinute
SarahWalker wrote:
What mouse driver are you using?
QuteMouse v1.9 [FreeDOS]. The game has also errors with sound :
FMOPL.C: write to unknown register: 1f
FMOPL.C: write to unknown register: 1e
FMOPL.C: write to unknown register: 1d
Can you reproduce it ?
Reply 363 of 1046, by SarahWalker
What parameters are being passed to EMM386?
Reply 365 of 1046, by SarahWalker
Hmm, those settings seem to work okay for me. What version of DOS are you using? What configuration in PCem?
SB16 error - PCem doesn't emulate the ASP/CSP on SB16 (it's an optional component, and isn't on most cards - including the SB16 Value PCem is trying to emulate) so a CSP detection error is entirely expected.
Reply 366 of 1046, by raidenii
DOS6.22, 430VX+ET4000 W32P+SB16+16M RAM
Reply 367 of 1046, by Stiletto
SarahWalker wrote:
Stiletto wrote:
Likewise, if there are any datasheets you struggled to find but eventually found while working on PCem, would you mind sharing them?
I don't have that much I think, probably nothing that isn't easily available :
* Analog Devices AD1418K
Was this a typo? Not finding much on this.
Investigating Gravis GF1 datasheet perhaps. Acer Labs/ALi M1429G / M1431 / M1433 datasheet I can find a reference to in a patent, but that's it so far.
do the Fandango!" - Queen
Stiletto
Reply 369 of 1046, by HalfMinute
Somebody is able to get Civilization 1 to work with PCem 8.1 or its something with my configuration ?
I've tried different mouse drivers, microsoft, Logitech. they all cause emulator to hang with similar errors.
Serial data 40 01 00
Serial data 40 13 0E
Serial data 40 06 04
Bad REP CA 0
x86 illegal 0011 80000011 018B:000001D4 F2
Serial data 40 05 03
Serial data 40 04 03
Serial data 43 3F 01
Serial data 43 3B 01
Serial data 43 3E 01
Serial data 43 3C 01
Serial data 40 00 02
x86 illegal 0011 80000011 8B0E:0000368B FF
Reply 370 of 1046, by coolhaken
I found that PCem seems can't mount a 1.2MB diskimage correctly.
I have a game "BATMAN : The Movie". There are 84 files.
Using "DIR" in DOSBox shows all the files and correct size.
But in PCem, the result is obviously wrong.
Attached are the screenshots of them.
    7.86 KiB
    7.41 KiB
    3.87 KiB
Reply 379 of 1046, by Zup
I wonder if there is any plan to add network emulation or "new" computers (it's a shame that there are no emulator for IBM PS/1).
I'm selling some stuff!
