PCEm. Another PC emulator.
Reply 700 of 1046, by dosquest
Ohhh, my mistake. The 586 was the internal monicker for the pentium.. Oopsie. 😜
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 701 of 1046, by Zup
What about the documentation? Could you update the readme to reflect the changes in filenames?
Also, what about an option to disable XTIDE ROM? If that ROM is present, any PC have it enabled by default. There is no way to switch between a PC1512 with HDD and a Sinclair PC200 without (OK, maybe the XTIDE won't detect a disk but it stills shows when booting).
I'm selling some stuff!
Reply 702 of 1046, by SA1988
PCem with networking capabilities added 😀
Download PCemN
Reply 703 of 1046, by ppgrainbow
Download PCemN
I'm getting a 404 Not Found error message when trying to download PCemN. I'm wondering if you can fix the broken link.
Reply 705 of 1046, by ppgrainbow
leileilol wrote:
Thank you so much! 😀 I'm trying it out now.
The only problem is that when I try to run DesqView/X (type dvx at the command prompt), PCem v9 hard reboots itself all of a sudden! This was not a issue in PCem v8.1 and later revisions that I tested out. And this was also not a issue when I ran DesqView/X under VMware Player.
I sure hope that there is a fix to this issue in PCem v9.1. I'm also hoping that preliminary networking support is officially included in PCem v10! 😀
Update: Okay, I have a problem with getting the network to work in PCem. Using the Win486 BIOS, I loaded the ISA version of the NE2000 packet driver and DOS successfully detected the network driver (Address 0x300 and the IRQ set to 10). I installed the Arachne web browser, configured all of the settings (including network driver detection) and Arachne fails to connect to the internet with these settings.
This occurs with both the BOOT/DHCP and manual settings. Also, when I exit the Arachne, all of the directories on drive C are gone! I end up stuck on the directory where Arachne is installed until I hard reset. 🙁
If you don't understand what I did wrong, please let me know.
Reply 706 of 1046, by SA1988
you have to select the host interface from the pcem.cfg file, parameter "netinterface" does that, for the number of interfaces attached to your computer, use niclist from Bochs and then put the number of the interface associated to it in netinterface on the pcem.cfg file:
e.g.: mine is "netinterface = 3" and the 3 equals to an Intel connection.
Reply 707 of 1046, by nerd73
I couldn't get PCemN to work because __gxx_personality_v0 wasn't located in libstdc++-6.dll.
Reply 708 of 1046, by Zup
Does that network card have a ROM socket (=can I use a ROM with it)?
Reply 709 of 1046, by SA1988
the ISA version of the ne2000 doesn't use a boot rom.
Reply 710 of 1046, by leileilol
now if only all web connections of PCem could be proxied through to the internet archive in a transparent way for faux retro browsing..., without the annoying javascript injections and having real 404s replace tia 404s
FUCK "AI"
Reply 711 of 1046, by ppgrainbow
Thank you very much for the help! 😀
Reply 712 of 1046, by nerd73
I decided to tinker a little bit with the source code.
Here's XTIDE on the IBM PCjr:
The attachment IDEPCjr.png is no longer available
Yeah it's a bit bugged up.
Reply 713 of 1046, by minigig
As anybody see a FPU emulation for the 286 or less? As a hobby I am writing code that takes advantage of a 287xl math-co (really a 387). I bet it is low on the agenda since so little takes advantage of math-co processors before the 386 and really before the 486.
Reply 714 of 1046, by nerd73
At long, long last, PCem get's pentium emulation.
Check the dev forum on the PCem forum for details.
Reply 715 of 1046, by Yamato
How do you make Windows NT to work? I tried on AMI486 and it didn't work after second TXT setup stage saying that it cannot install on the current processor. Also tried both pentiums and it still doesn't.
Reply 716 of 1046, by SarahWalker
Which version of NT, and which 486? Can you provide a screenshot of the error?
Reply 717 of 1046, by Yamato
Oh sorry, wasn't specific. Windows NT 3.1 with all 486 CPUs. Yes, i can provide a screenshot, coming soon.
Reply 718 of 1046, by leileilol
You sure you're installing the i386 version?
FUCK "AI"
Reply 719 of 1046, by Yamato
Pretty sure, ran setup from i386 folder from DOS.
