First post, by Midi
Before I knew that much about midi I bought a GM soundfont not realising I should have bought the GM/GS version.
But I have some other GM/GS soundfonts so I want to know is there a way to stack them so that it will always use the instrument from the GM soundfont unless it is a GS instrument then it will use it from the GM/GS soundfont.
Can it be done? I have foobar with bassmidi, MPC with coolsoft and XMplay but I could use another player if I needed to.
This is for listening to classic midi's not playing in game.
Mr. Midi.
Reply 1 of 14, by PhilsComputerLab
VirtualMIDISynth allows this. Then, just play MIDI files in Media Player 😀
YouTube, Facebook, Website
Reply 2 of 14, by Midi
Thanks, so if I put the GM one below the GM/GS one I won't be giving priority to a general midi instrument over a gs one that is a version of the general one?
Mr. Midi.
Reply 3 of 14, by PhilsComputerLab
Best to just try it out.
Reply 4 of 14, by Midi
Seems that all the programs replace any GS instrument with a gm one, I think.
I don't have any testing program that can even choose GS instruments but in some midi files that have gs instruments they definitely sound very different when the gm one is put on top.
Mr. Midi.
Reply 5 of 14, by gdjacobs
Timidity can do fairly sophisticated layering of soundfonts.
Some examples here:
http://ocmnet.com/saxguru/faqSf2.html
More reference material (translate file paths uNiX->Windows as required):
http://manpages.ubuntu.com/manpages/saucy/man … dity.cfg.5.html
I don't know the GM/GS/Yamaha patch maps well, so I found some tables:
http://www.voidaudio.net/gsinstrument.html
http://download.yamaha.com/api/asset/file/?la … m&asset_id=2376
Reply 6 of 14, by Midi
Ok thanks, it looks like Linux is the way to go for midi player configurability.
Mr. Midi.
Reply 7 of 14, by deemster
Which soundfont did you buy, Midi?
Reply 8 of 14, by gdjacobs
You can run Timidity in Windows.
Reply 9 of 14, by Midi
Thanks just getting started with Timidity in windows, just stuck on a problem with an error message. When I put it on 24 bit output it doesn't play properly so I installed asio4all but then I get an error saying 'Couldn't open port audio (asio) output.wav'. It might be better in linux but last time I checked I couldn't get my soundcard (M-audio fast track pro) to work at higher than 44.1/16bit in linux.
First I want to stack instruments from Jazman GM on top of another GM/GS soundfont (but not replacing any GS version instruments with GM ones), also I have some non midi mapped soundfonts such as 24bit drum kits and a piano soundfonts cd and some others I bought earlier that I would like to try.
Ideally it would be cool to have a screen showing all the instruments in midi GM GS XG and be able to change the sf2 or sfz file they are using (being able to select instrument and patch(so I can use multi instrument sf2 files that are not designed for midi)).
Mr. Midi.
Reply 10 of 14, by gdjacobs
Re: Fast Track Pro in Linux
There are some limitations on this device which require tradeoffs in features vs performance. >48khz sampling requires reducing the number of active input and/or output channels due to usb bandwidth limitations.
The device_setup module parameter allows you to reconfigure things. See http://alsa.opensrc.org/M-Audio_FastTrack_Pro for more, and remember how to perform binary arithmetic.
Can you describe in detail how you execute Timidity including any parameters you use?
Reply 11 of 14, by Midi
Thanks, I was trying Timidity in windows, I only just installed it an added 1 soundfont sf2 then I played a midi file and it worked but when I changed precision to 24 bit it made a high pitched sound while playing. So I tried some other output settings and none of them seemed to have any sound output so I tried installing asio4all but with that I get the filename error, the setting in timidity is set to auto filename. I'm a newbie to this 😒
I'll look at getting 96khz 24 bit with fast track pro in linux next, but I'm a newbie there too. 😒
Mr. Midi.
Reply 12 of 14, by deemster
IMO Timidity is pretty mediorce... I recommend anything that uses Bassmdi (The midi plugin for XMPLAY for casual listening and Coolsoft VirtualMidiSynth for gaming)
You can stack soundfonts with it easily 😀
Reply 13 of 14, by gdjacobs
Cool. I've heard some criticism of the fidelity of Timidity, but I'm interested to know where it is deficient (in the interest of improvement). Any comments?
Reply 14 of 14, by DracoNihil
TiMidity++ has never properly handled alot of SF2 features, causing alot of SoundFonts developed on Live! or Audigy devices to sound completely incorrect. Even FluidSynth has downfalls in that regard.
BASSMIDI is the only library I know of that tries to accurately utilize SoundFont 2.0 fully.
― Κυνικός Δράκων
