First post, by SoftPCMuseum_
This time, since the other one was locked, I'm making a new topic.
The old topic was locked because I forgot to remove some disk images in the copyright-free versions of the emulator that I left in by accident. These have been removed, and so have the original links. Please do not request these anymore. I certainly apologize if I left in those disk images by accident. I thought that they had been removed but it looks like I forgot to remove them the last time. This time, they actually have been, and so the links are clean without any copyright-infringing code whatsoever. Thanks for bringing this to my attention though, since I might not have noticed it otherwise.
List of machines supported in the latest release (Release A001):
- IBM Personal Computer (Model 5150/5160)
- IBM Portable PC (Model 5155)
- COMPAQ Portable/Portable Plus (certain features disabled in compiled binaries; re-enable in source code and recompile from there)
- AT&T 6300
Download links (WITHOUT copyrighted material):
- Binaries: http://www.filedropper.com/tvccreleasea001copyrightfree_1
- Source code: http://www.filedropper.com/tvccreleasea001srccopyrightfree_1
FreeDOS is used in place of PC-DOS in the versions distributed in the above links.
Again, no personal attacks are allowed. If a user has an issue with this then they may discuss it civilly without causing any more trouble. Any requests for copyrighted material will also be reported regardless of the user.
