Reply 920 of 1046, by vvbee
- Oldbie
The problem with the right alt not working with pcem in wine is to do with it getting mapped on this layout to iso_level3_shift instead of alt_r, which apparently is correct but pcem doesn't know to anticipate it. Mapping it manually with xmodmap to alt_r makes it work with pcem but breaks it elsewhere.
I sorted the linux version's compile errors, but the finished binary bails out saying it can't locate roms. The roms are there and work with the windows version, so sounds like a path/filename issue. No doubt I can get it to work with more time spent on it, but in general I think precompiled pcem binaries for linux should be a thing. Target and test for something popular like ubuntu where users don't want to build software from sources, and make messing with the compiler a fallback.
