Accessing CR2/CR3 at CPL 1,2,3?
Emulation of old PCs, PC hardware, or PC peripherals.
Postby superfury » 2018-10-11 @ 12:22
Reading the 80486 manual, it lists the following control instructions as priveleged(CPL0 only, any other CPL levels(1,2,3) are illegal):
- CLTS
- HLT
- LGDT
- LIDT
- LLDT
- LMSW
- LTR
- MOV to/from CR0
- MOV to/from DRn
- MOV to/from TRn
Does that mean that MOV to/from CR2/CR3 is allowed always(CR1 being #UD always)? Or is that a documentation error?
superfury
Re: Accessing CR2/CR3 at CPL 1,2,3?
Postby Stenzek » 2018-10-13 @ 04:17
From the Pentium manual:
- PMode: #GP(0) if CPL != 0 for all control registers, #GP(0) if writing to reserved bits of CR4
- Real Mode: Interrupt 13 (which is #GP) if writing to reserved bits of CR4
- V8086 Mode: #GP(0) unconditionally
Which makes sense, you wouldn't want userspace to be able to change the page directory address, as that would render the protection useless.
Stenzek
Return to PC Emulation
Who is online
