This is what happens at CPL 3:
The attachment debugger_Windows95segment117.7z is no longer available
Edit: So the invalid value is at physical memory location 20a1b0.
It's popped right before the instruction (POP [ESP+08]). The stack was at physical address 20a1a8 at that point.
Further upm that's written by a PUSH DWORD DS:[1320] instruction(FF/5). DS was 12F at that point.
It's source seems to have been memory location 1bac0(paged)/233ac0(physical).
Tracing it back, I arrive at the previous instruction(immediately before the RETF), which loads the address using a POP into [ESP+08], which is the code segment it's returning to.
Tracing back it's source, I arrive at:
0117:000064c9 66 FF 36 20 13 push dword ds:[1320]
Which pushes said value on the stack.
Further back, there's some calculation:
Copy code to clipboard 1 0117:00004a46 8B F0 mov si,ax RealRAM(p):0020f014=0b(); RAM(p):0026f014=0b(); Physical(p):0026f014=0b(); Paged(p):00012014=0b(); Normal(p):00004a54=0b(); RealRAM(p):0020f015=f6(?); RAM(p):0026f015=f6(?); Physical(p):0026f015=f6(?); Paged(p):00012015=f6(?); Normal(p):00004a55=f6(?) 2 Registers: 3 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 4 ESP: 00001e90 EBP: 00001ea2 ESI: 00000165 EDI: 00001ff8 5 CS: 0117 DS: 0097 ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 6 EIP: 00004a46 EFLAGS: 00000206 7 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 8 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 9 DR6: 00000000 DR7: 00000000 10 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 11 FLAGSINFO: 00000000000000vr0n00odItsz0a0P1c 12 0117:00004a48 EB 10 jmp 00004a5a RealRAM(p):0020f016=75(u); RAM(p):0026f016=75(u); Physical(p):0026f016=75(u); Paged(p):00012016=75(u); Normal(p):00004a56=75(u); RealRAM(p):0020f017=39(9); RAM(p):0026f017=39(9); Physical(p):0026f017=39(9); Paged(p):00012017=39(9); Normal(p):00004a57=39(9); RealRAM(p):0020f01a=2e(.); RAM(p):0026f01a=2e(.); Physical(p):0026f01a=2e(.); Paged(p):0001201a=2e(.); Normal(p):00004a5a=2e(.); RealRAM(p):0020f01b=8e(?); RAM(p):0026f01b=8e(?); Physical(p):0026f01b=8e(?); Paged(p):0001201b=8e(?); Normal(p):00004a5b=8e(?); RealRAM(p):0020f01c=1e(); RAM(p):0026f01c=1e(); Physical(p):0026f01c=1e(); Paged(p):0001201c=1e(); Normal(p):00004a5c=1e(); RealRAM(p):0020f01d=02(); RAM(p):0026f01d=02(); Physical(p):0026f01d=02(); Paged(p):0001201d=02(); Normal(p):00004a5d=02(); RealRAM(p):0020f01e=00( ); RAM(p):0026f01e=00( ); Physical(p):0026f01e=00( ); Paged(p):0001201e=00( ); Normal(p):00004a5e=00( ); RealRAM(p):0020f01f=29()); RAM(p):0026f01f=29()); Physical(p):0026f01f=29()); Paged(p):0001201f=29()); Normal(p):00004a5f=29()); RealRAM(p):0020f020=0e(); RAM(p):0026f020=0e(); Physical(p):0026f020=0e(); Paged(p):00012020=0e(); Normal(p):00004a60=0e(); RealRAM(p):0020f021=ae(?); RAM(p):0026f021=ae(?); Physical(p):0026f021=ae(?); Paged(p):00012021=ae(?); Normal(p):00004a61=ae(?); RealRAM(p):0020f022=13(); RAM(p):0026f022=13(); Physical(p):0026f022=13(); Paged(p):00012022=13(); Normal(p):00004a62=13(); RealRAM(p):0020f023=81(?); RAM(p):0026f023=81(?); Physical(p):0026f023=81(?); Paged(p):00012023=81(?); Normal(p):00004a63=81(?); RealRAM(p):0020f024=3e(>); RAM(p):0026f024=3e(>); Physical(p):0026f024=3e(>); Paged(p):00012024=3e(>); Normal(p):00004a64=3e(>); RealRAM(p):0020f025=ae(?); RAM(p):0026f025=ae(?); Physical(p):0026f025=ae(?); Paged(p):00012025=ae(?); Normal(p):00004a65=ae(?); RealRAM(p):0020f026=13(); RAM(p):0026f026=13(); Physical(p):0026f026=13(); Paged(p):00012026=13(); Normal(p):00004a66=13(); RealRAM(p):0020f027=00( ); RAM(p):0026f027=00( ); Physical(p):0026f027=00( ); Paged(p):00012027=00( ); Normal(p):00004a67=00( ); RealRAM(p):0020f028=01(); RAM(p):0026f028=01(); Physical(p):0026f028=01(); Paged(p):00012028=01(); Normal(p):00004a68=01(); RealRAM(p):0020f029=73(s); RAM(p):0026f029=73(s); Physical(p):0026f029=73(s); Paged(p):00012029=73(s); Normal(p):00004a69=73(s) 13 Registers: 14 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 15 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 16 CS: 0117 DS: 0097 ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 17 EIP: 00004a48 EFLAGS: 00000206 18 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 19 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 20 DR6: 00000000 DR7: 00000000 21 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 22 FLAGSINFO: 00000000000000vr0n00odItsz0a0P1c 23 MMU: Reading from real(r): 00854128=9f (?) 24 Reading from RAM(r): 008b4128=9f (?) 25 Reading from physical memory(r): 008b4128=9f (?) 26 Reading from paged memory(r): 008b4128=9f (?) 27 MMU: Reading from real(r): 00854129=4b (K) 28 Reading from RAM(r): 008b4129=4b (K) 29 Reading from physical memory(r): 008b4129=4b (K) 30 Reading from paged memory(r): 008b4129=4b (K) 31 MMU: Reading from real(r): 0085412a=a0 (?) 32 Reading from RAM(r): 008b412a=a0 (?) 33 Reading from physical memory(r): 008b412a=a0 (?) 34 Reading from paged memory(r): 008b412a=a0 (?) 35 MMU: Reading from real(r): 0085412b=a7 (?) 36 Reading from RAM(r): 008b412b=a7 (?) 37 Reading from physical memory(r): 008b412b=a7 (?) 38 Reading from paged memory(r): 008b412b=a7 (?) 39 MMU: Reading from real(r): 0085412c=01 () 40 Reading from RAM(r): 008b412c=01 () 41 Reading from physical memory(r): 008b412c=01 () 42 Reading from paged memory(r): 008b412c=01 () 43 MMU: Reading from real(r): 0085412d=f3 (?) 44 Reading from RAM(r): 008b412d=f3 (?) 45 Reading from physical memory(r): 008b412d=f3 (?) 46 Reading from paged memory(r): 008b412d=f3 (?) 47 MMU: Reading from real(r): 0085412e=00 ( ) 48 Reading from RAM(r): 008b412e=00 ( ) 49 Reading from physical memory(r): 008b412e=00 ( ) 50 Reading from paged memory(r): 008b412e=00 ( ) 51 MMU: Reading from real(r): 0085412f=00 ( ) 52 Reading from RAM(r): 008b412f=00 ( ) 53 Reading from physical memory(r): 008b412f=00 ( ) 54 Reading from paged memory(r): 008b412f=00 ( ) 55 0117:00004a5a 2E 8E 1E 02 00 mov ds,word cs:[0002] RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):00245037=00( ); RAM(r):002a5037=00( ); Physical(r):002a5037=00( ); RealRAM(r):00245036=29()); RAM(r):002a5036=29()); Physical(r):002a5036=29()); RealRAM(r):00245035=a2(?); RAM(r):002a5035=a2(?); Physical(r):002a5035=a2(?); RealRAM(r):00245034=67(g); RAM(r):002a5034=67(g); Physical(r):002a5034=67(g); RealRAM(r):0023a5c2=2f(/); RAM(r):0029a5c2=2f(/); Physical(r):0029a5c2=2f(/); Paged(r):0000d5c2=2f(/); RealRAM(r):0023a5c3=01(); RAM(r):0029a5c3=01(); Physical(r):0029a5c3=01(); Paged(r):0000d5c3=01(); RealRAM(r):00226803=00( ); RAM(r):00286803=00( ); Physical(r):00286803=00( ); RealRAM(r):00226802=2a(*); RAM(r):00286802=2a(*); Physical(r):00286802=2a(*); RealRAM(r):00226801=12(); RAM(r):00286801=12(); Physical(r):00286801=12(); RealRAM(r):00226800=67(g); RAM(r):00286800=67(g); Physical(r):00286800=67(g); RealRAM(r):0024125f=00( ); RAM(r):002a125f=00( ); Physical(r):002a125f=00( ); RealRAM(r):0024125e=8b(?); RAM(r):002a125e=8b(?); Physical(r):002a125e=8b(?); RealRAM(r):0024125d=42(B); RAM(r):002a125d=42(B); Physical(r):002a125d=42(B); RealRAM(r):0024125c=67(g); RAM(r):002a125c=67(g); Physical(r):002a125c=67(g) 56 Registers: 57 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 58 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 59 CS: 0117 DS: 0097 ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 60 EIP: 00004a5a EFLAGS: 00000206 … Show last 225 lines 61 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 62 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 63 DR6: 00000000 DR7: 00000000 64 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 65 FLAGSINFO: 00000000000000vr0n00odItsz0a0P1c 66 RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f02a=2b(+); RAM(p):0026f02a=2b(+); Physical(p):0026f02a=2b(+); Paged(p):0001202a=2b(+); Normal(p):00004a6a=2b(+); RealRAM(p):0020f02b=2e(.); RAM(p):0026f02b=2e(.); Physical(p):0026f02b=2e(.); Paged(p):0001202b=2e(.); Normal(p):00004a6b=2e(.); RealRAM(p):0020f02c=0f(); RAM(p):0026f02c=0f(); Physical(p):0026f02c=0f(); Paged(p):0001202c=0f(); Normal(p):00004a6c=0f(); RealRAM(p):0020f02d=03(); RAM(p):0026f02d=03(); Physical(p):0026f02d=03(); Paged(p):0001202d=03(); Normal(p):00004a6d=03(); RealRAM(p):0020f02e=1e(); RAM(p):0026f02e=1e(); Physical(p):0026f02e=1e(); Paged(p):0001202e=1e(); Normal(p):00004a6e=1e(); RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024506f=00( ); RAM(r):002a506f=00( ); Physical(r):002a506f=00( ); RealRAM(r):0024506e=23(#); RAM(r):002a506e=23(#); Physical(r):002a506e=23(#); RealRAM(r):0024506d=32(2); RAM(r):002a506d=32(2); Physical(r):002a506d=32(2); RealRAM(r):0024506c=67(g); RAM(r):002a506c=67(g); Physical(r):002a506c=67(g); RealRAM(r):001d3b4e=d7(?); RAM(r):00233b4e=d7(?); Physical(r):00233b4e=d7(?); Paged(r):0001bb4e=d7(?); RealRAM(r):001d3b4f=01(); RAM(r):00233b4f=01(); Physical(r):00233b4f=01(); Paged(r):0001bb4f=01() 67 0117:00004a5f 29 0E AE 13 sub word ds:[13ae],cx Paged(w):0001bb4e=d4(?); Physical(w):00233b4e=d4(?); RAM(w):00233b4e=d4(?); RealRAM(w):001d3b4e=d4(?); Paged(w):0001bb4f=01(); Physical(w):00233b4f=01(); RAM(w):00233b4f=01(); RealRAM(w):001d3b4f=01() 68 Registers: 69 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 70 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 71 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 72 EIP: 00004a5f EFLAGS: 00000206 73 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 74 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 75 DR6: 00000000 DR7: 00000000 76 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 77 FLAGSINFO: 00000000000000vr0n00odItsz0a0P1c 78 0117:00004a63 81 3E AE 13 00 01 cmp word ds:[13ae],0100 RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f02f=06(); RAM(p):0026f02f=06(); Physical(p):0026f02f=06(); Paged(p):0001202f=06(); Normal(p):00004a6f=06(); RealRAM(p):0020f030=00( ); RAM(p):0026f030=00( ); Physical(p):0026f030=00( ); Paged(p):00012030=00( ); Normal(p):00004a70=00( ); RealRAM(p):0020f031=81(?); RAM(p):0026f031=81(?); Physical(p):0026f031=81(?); Paged(p):00012031=81(?); Normal(p):00004a71=81(?); RealRAM(p):0020f032=fb(?); RAM(p):0026f032=fb(?); Physical(p):0026f032=fb(?); Paged(p):00012032=fb(?); Normal(p):00004a72=fb(?); RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024506f=00( ); RAM(r):002a506f=00( ); Physical(r):002a506f=00( ); RealRAM(r):0024506e=23(#); RAM(r):002a506e=23(#); Physical(r):002a506e=23(#); RealRAM(r):0024506d=32(2); RAM(r):002a506d=32(2); Physical(r):002a506d=32(2); RealRAM(r):0024506c=67(g); RAM(r):002a506c=67(g); Physical(r):002a506c=67(g); RealRAM(r):001d3b4e=d4(?); RAM(r):00233b4e=d4(?); Physical(r):00233b4e=d4(?); Paged(r):0001bb4e=d4(?); RealRAM(r):001d3b4f=01(); RAM(r):00233b4f=01(); Physical(r):00233b4f=01(); Paged(r):0001bb4f=01() 79 Registers: 80 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 81 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 82 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 83 EIP: 00004a63 EFLAGS: 00000206 84 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 85 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 86 DR6: 00000000 DR7: 00000000 87 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 88 FLAGSINFO: 00000000000000vr0n00odItsz0a0P1c 89 0117:00004a69 73 2B jnc 00004a96 RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f033=00( ); RAM(p):0026f033=00( ); Physical(p):0026f033=00( ); Paged(p):00012033=00( ); Normal(p):00004a73=00( ); RealRAM(p):0020f034=f0(?); RAM(p):0026f034=f0(?); Physical(p):0026f034=f0(?); Paged(p):00012034=f0(?); Normal(p):00004a74=f0(?); RealRAM(p):0020f035=77(w); RAM(p):0026f035=77(w); Physical(p):0026f035=77(w); Paged(p):00012035=77(w); Normal(p):00004a75=77(w); RealRAM(p):0020f036=1f(); RAM(p):0026f036=1f(); Physical(p):0026f036=1f(); Paged(p):00012036=1f(); Normal(p):00004a76=1f(); RealRAM(p):0020f037=50(P); RAM(p):0026f037=50(P); Physical(p):0026f037=50(P); Paged(p):00012037=50(P); Normal(p):00004a77=50(P); RealRAM(p):0020f038=51(Q); RAM(p):0026f038=51(Q); Physical(p):0026f038=51(Q); Paged(p):00012038=51(Q); Normal(p):00004a78=51(Q); RealRAM(p):0020f056=83(?); RAM(p):0026f056=83(?); Physical(p):0026f056=83(?); Paged(p):00012056=83(?); Normal(p):00004a96=83(?); RealRAM(p):0020f057=3e(>); RAM(p):0026f057=3e(>); Physical(p):0026f057=3e(>); Paged(p):00012057=3e(>); Normal(p):00004a97=3e(>); RealRAM(p):0020f058=32(2); RAM(p):0026f058=32(2); Physical(p):0026f058=32(2); Paged(p):00012058=32(2); Normal(p):00004a98=32(2); RealRAM(p):0020f059=12(); RAM(p):0026f059=12(); Physical(p):0026f059=12(); Paged(p):00012059=12(); Normal(p):00004a99=12(); RealRAM(p):0020f05a=00( ); RAM(p):0026f05a=00( ); Physical(p):0026f05a=00( ); Paged(p):0001205a=00( ); Normal(p):00004a9a=00( ); RealRAM(p):0020f05b=74(t); RAM(p):0026f05b=74(t); Physical(p):0026f05b=74(t); Paged(p):0001205b=74(t); Normal(p):00004a9b=74(t); RealRAM(p):0020f05c=23(#); RAM(p):0026f05c=23(#); Physical(p):0026f05c=23(#); Paged(p):0001205c=23(#); Normal(p):00004a9c=23(#); RealRAM(p):0020f05d=66(f); RAM(p):0026f05d=66(f); Physical(p):0026f05d=66(f); Paged(p):0001205d=66(f); Normal(p):00004a9d=66(f); RealRAM(p):0020f05e=50(P); RAM(p):0026f05e=50(P); Physical(p):0026f05e=50(P); Paged(p):0001205e=50(P); Normal(p):00004a9e=50(P); RealRAM(p):0020f05f=67(g); RAM(p):0026f05f=67(g); Physical(p):0026f05f=67(g); Paged(p):0001205f=67(g); Normal(p):00004a9f=67(g); RealRAM(p):0020f060=66(f); RAM(p):0026f060=66(f); Physical(p):0026f060=66(f); Paged(p):00012060=66(f); Normal(p):00004aa0=66(f); RealRAM(p):0020f061=8d(?); RAM(p):0026f061=8d(?); Physical(p):0026f061=8d(?); Paged(p):00012061=8d(?); Normal(p):00004aa1=8d(?); RealRAM(p):0020f062=44(D); RAM(p):0026f062=44(D); Physical(p):0026f062=44(D); Paged(p):00012062=44(D); Normal(p):00004aa2=44(D); RealRAM(p):0020f063=ce(?); RAM(p):0026f063=ce(?); Physical(p):0026f063=ce(?); Paged(p):00012063=ce(?); Normal(p):00004aa3=ce(?); RealRAM(p):0020f064=f8(?); RAM(p):0026f064=f8(?); Physical(p):0026f064=f8(?); Paged(p):00012064=f8(?); Normal(p):00004aa4=f8(?); RealRAM(p):0020f065=d1(?); RAM(p):0026f065=d1(?); Physical(p):0026f065=d1(?); Paged(p):00012065=d1(?); Normal(p):00004aa5=d1(?) 90 Registers: 91 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 92 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 93 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 94 EIP: 00004a69 EFLAGS: 00000206 95 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 96 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 97 DR6: 00000000 DR7: 00000000 98 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 99 FLAGSINFO: 00000000000000vr0n00odItsz0a0P1c 100 0117:00004a96 83 3E 32 12 00 cmp word ds:[1232],0000 RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024506f=00( ); RAM(r):002a506f=00( ); Physical(r):002a506f=00( ); RealRAM(r):0024506e=23(#); RAM(r):002a506e=23(#); Physical(r):002a506e=23(#); RealRAM(r):0024506d=32(2); RAM(r):002a506d=32(2); Physical(r):002a506d=32(2); RealRAM(r):0024506c=67(g); RAM(r):002a506c=67(g); Physical(r):002a506c=67(g); RealRAM(r):001d39d2=00( ); RAM(r):002339d2=00( ); Physical(r):002339d2=00( ); Paged(r):0001b9d2=00( ); RealRAM(r):001d39d3=80(?); RAM(r):002339d3=80(?); Physical(r):002339d3=80(?); Paged(r):0001b9d3=80(?) 101 Registers: 102 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 103 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 104 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 105 EIP: 00004a96 EFLAGS: 00000206 106 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 107 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 108 DR6: 00000000 DR7: 00000000 109 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 110 FLAGSINFO: 00000000000000vr0n00odItsz0a0P1c 111 0117:00004a9b 74 23 jz 00004ac0 RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f066=e8(?); RAM(p):0026f066=e8(?); Physical(p):0026f066=e8(?); Paged(p):00012066=e8(?); Normal(p):00004aa6=e8(?); RealRAM(p):0020f067=3b(;); RAM(p):0026f067=3b(;); Physical(p):0026f067=3b(;); Paged(p):00012067=3b(;); Normal(p):00004aa7=3b(;); RealRAM(p):0020f068=06(); RAM(p):0026f068=06(); Physical(p):0026f068=06(); Paged(p):00012068=06(); Normal(p):00004aa8=06(); RealRAM(p):0020f069=32(2); RAM(p):0026f069=32(2); Physical(p):0026f069=32(2); Paged(p):00012069=32(2); Normal(p):00004aa9=32(2); RealRAM(p):0020f06a=12(); RAM(p):0026f06a=12(); Physical(p):0026f06a=12(); Paged(p):0001206a=12(); Normal(p):00004aaa=12() 112 Registers: 113 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 114 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 115 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 116 EIP: 00004a9b EFLAGS: 00000286 117 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 118 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 119 DR6: 00000000 DR7: 00000000 120 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 121 FLAGSINFO: 00000000000000vr0n00odItSz0a0P1c 122 0117:00004a9d 66 50 push eax RealRAM(p):0020f06b=66(f); RAM(p):0026f06b=66(f); Physical(p):0026f06b=66(f); Paged(p):0001206b=66(f); Normal(p):00004aab=66(f); RealRAM(p):0020f06c=58(X); RAM(p):0026f06c=58(X); Physical(p):0026f06c=58(X); Paged(p):0001206c=58(X); Normal(p):00004aac=58(X); RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024507f=00( ); RAM(r):002a507f=00( ); Physical(r):002a507f=00( ); RealRAM(r):0024507e=20( ); RAM(r):002a507e=20( ); Physical(r):002a507e=20( ); RealRAM(r):0024507d=a2(?); RAM(r):002a507d=a2(?); Physical(r):002a507d=a2(?); RealRAM(r):0024507c=67(g); RAM(r):002a507c=67(g); Physical(r):002a507c=67(g); Paged(w):0001f19c=48(H); Paged(w):0001f19d=01(); Paged(w):0001f19e=01(); Paged(w):0001f19f=00( ); Physical(w):0020a19c=48(H); RAM(w):0020a19c=48(H); RealRAM(w):001aa19c=48(H); Physical(w):0020a19d=01(); RAM(w):0020a19d=01(); RealRAM(w):001aa19d=01(); Physical(w):0020a19e=01(); RAM(w):0020a19e=01(); RealRAM(w):001aa19e=01(); Physical(w):0020a19f=00( ); RAM(w):0020a19f=00( ); RealRAM(w):001aa19f=00( ) 123 Registers: 124 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 125 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 126 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 127 EIP: 00004a9d EFLAGS: 00000286 128 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 129 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 130 DR6: 00000000 DR7: 00000000 131 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 132 FLAGSINFO: 00000000000000vr0n00odItSz0a0P1c 133 0117:00004a9f 67 66 8D 44 CE F8 lea eax,dword ds:[esi+ecx*8-08] RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f06d=72(r); RAM(p):0026f06d=72(r); Physical(p):0026f06d=72(r); Paged(p):0001206d=72(r); Normal(p):00004aad=72(r); RealRAM(p):0020f06e=11(); RAM(p):0026f06e=11(); Physical(p):0026f06e=11(); Paged(p):0001206e=11(); Normal(p):00004aae=11() 134 Registers: 135 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 136 ESP: 00001e8c EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 137 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 138 EIP: 00004a9f EFLAGS: 00000286 139 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 140 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 141 DR6: 00000000 DR7: 00000000 142 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 143 FLAGSINFO: 00000000000000vr0n00odItSz0a0P1c 144 0117:00004aa5 D1 E8 shr ax,1 RealRAM(p):0020f06f=8b(?); RAM(p):0026f06f=8b(?); Physical(p):0026f06f=8b(?); Paged(p):0001206f=8b(?); Normal(p):00004aaf=8b(?); RealRAM(p):0020f070=de(?); RAM(p):0026f070=de(?); Physical(p):0026f070=de(?); Paged(p):00012070=de(?); Normal(p):00004ab0=de(?); RealRAM(p):0020f071=33(3); RAM(p):0026f071=33(3); Physical(p):0026f071=33(3); Paged(p):00012071=33(3); Normal(p):00004ab1=33(3); RealRAM(p):0020f072=f6(?); RAM(p):0026f072=f6(?); Physical(p):0026f072=f6(?); Paged(p):00012072=f6(?); Normal(p):00004ab2=f6(?); RealRAM(p):0020f073=80(?); RAM(p):0026f073=80(?); Physical(p):0026f073=80(?); Paged(p):00012073=80(?); Normal(p):00004ab3=80(?); RealRAM(p):0020f074=cb(?); RAM(p):0026f074=cb(?); Physical(p):0026f074=cb(?); Paged(p):00012074=cb(?); Normal(p):00004ab4=cb(?) 145 Registers: 146 EAX: 00000158 EBX: 000000f8 ECX: 00000003 EDX: 00000160 147 ESP: 00001e8c EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 148 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 149 EIP: 00004aa5 EFLAGS: 00000286 150 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 151 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 152 DR6: 00000000 DR7: 00000000 153 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 154 FLAGSINFO: 00000000000000vr0n00odItSz0a0P1c 155 0117:00004aa7 3B 06 32 12 cmp ax,word ds:[1232] RealRAM(p):0020f075=07(); RAM(p):0026f075=07(); Physical(p):0026f075=07(); Paged(p):00012075=07(); Normal(p):00004ab5=07(); RealRAM(p):0020f076=b8(?); RAM(p):0026f076=b8(?); Physical(p):0026f076=b8(?); Paged(p):00012076=b8(?); Normal(p):00004ab6=b8(?); RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024506f=00( ); RAM(r):002a506f=00( ); Physical(r):002a506f=00( ); RealRAM(r):0024506e=23(#); RAM(r):002a506e=23(#); Physical(r):002a506e=23(#); RealRAM(r):0024506d=32(2); RAM(r):002a506d=32(2); Physical(r):002a506d=32(2); RealRAM(r):0024506c=67(g); RAM(r):002a506c=67(g); Physical(r):002a506c=67(g); RealRAM(r):001d39d2=00( ); RAM(r):002339d2=00( ); Physical(r):002339d2=00( ); Paged(r):0001b9d2=00( ); RealRAM(r):001d39d3=80(?); RAM(r):002339d3=80(?); Physical(r):002339d3=80(?); Paged(r):0001b9d3=80(?) 156 Registers: 157 EAX: 000000ac EBX: 000000f8 ECX: 00000003 EDX: 00000160 158 ESP: 00001e8c EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 159 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 160 EIP: 00004aa7 EFLAGS: 00000216 161 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 162 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 163 DR6: 00000000 DR7: 00000000 164 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 165 FLAGSINFO: 00000000000000vr0n00odItsz0A0P1c 166 RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f077=01(); RAM(p):0026f077=01(); Physical(p):0026f077=01(); Paged(p):00012077=01(); Normal(p):00004ab7=01(); RealRAM(p):0020f078=00( ); RAM(p):0026f078=00( ); Physical(p):0026f078=00( ); Paged(p):00012078=00( ); Normal(p):00004ab8=00( ); RealRAM(p):0020f079=cd(?); RAM(p):0026f079=cd(?); Physical(p):0026f079=cd(?); Paged(p):00012079=cd(?); Normal(p):00004ab9=cd(?); RealRAM(p):0020f07a=31(1); RAM(p):0026f07a=31(1); Physical(p):0026f07a=31(1); Paged(p):0001207a=31(1); Normal(p):00004aba=31(1); RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024507f=00( ); RAM(r):002a507f=00( ); Physical(r):002a507f=00( ); RealRAM(r):0024507e=20( ); RAM(r):002a507e=20( ); Physical(r):002a507e=20( ); RealRAM(r):0024507d=a2(?); RAM(r):002a507d=a2(?); Physical(r):002a507d=a2(?); RealRAM(r):0024507c=67(g); RAM(r):002a507c=67(g); Physical(r):002a507c=67(g) 167 0117:00004aab 66 58 pop eax RealRAM(r):001aa19c=48(H); RAM(r):0020a19c=48(H); Physical(r):0020a19c=48(H); Paged(r):0001f19c=48(H); RealRAM(r):001aa19d=01(); RAM(r):0020a19d=01(); Physical(r):0020a19d=01(); Paged(r):0001f19d=01(); RealRAM(r):001aa19e=01(); RAM(r):0020a19e=01(); Physical(r):0020a19e=01(); Paged(r):0001f19e=01(); RealRAM(r):001aa19f=00( ); RAM(r):0020a19f=00( ); Physical(r):0020a19f=00( ); Paged(r):0001f19f=00( ) 168 Registers: 169 EAX: 000000ac EBX: 000000f8 ECX: 00000003 EDX: 00000160 170 ESP: 00001e8c EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 171 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 172 EIP: 00004aab EFLAGS: 00000a87 173 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 174 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 175 DR6: 00000000 DR7: 00000000 176 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 177 FLAGSINFO: 00000000000000vr0n00OdItSz0a0P1C 178 0117:00004aad 72 11 jc 00004ac0 RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f07b=8d(?); RAM(p):0026f07b=8d(?); Physical(p):0026f07b=8d(?); Paged(p):0001207b=8d(?); Normal(p):00004abb=8d(?); RealRAM(p):0020f07c=5f(_); RAM(p):0026f07c=5f(_); Physical(p):0026f07c=5f(_); Paged(p):0001207c=5f(_); Normal(p):00004abc=5f(_); RealRAM(p):0020f080=2e(.); RAM(p):0026f080=2e(.); Physical(p):0026f080=2e(.); Paged(p):00012080=2e(.); Normal(p):00004ac0=2e(.); RealRAM(p):0020f081=8e(?); RAM(p):0026f081=8e(?); Physical(p):0026f081=8e(?); Paged(p):00012081=8e(?); Normal(p):00004ac1=8e(?); RealRAM(p):0020f082=1e(); RAM(p):0026f082=1e(); Physical(p):0026f082=1e(); Paged(p):00012082=1e(); Normal(p):00004ac2=1e(); RealRAM(p):0020f083=06(); RAM(p):0026f083=06(); Physical(p):0026f083=06(); Paged(p):00012083=06(); Normal(p):00004ac3=06(); RealRAM(p):0020f084=00( ); RAM(p):0026f084=00( ); Physical(p):0026f084=00( ); Paged(p):00012084=00( ); Normal(p):00004ac4=00( ); RealRAM(p):0020f085=1e(); RAM(p):0026f085=1e(); Physical(p):0026f085=1e(); Paged(p):00012085=1e(); Normal(p):00004ac5=1e(); RealRAM(p):0020f086=2e(.); RAM(p):0026f086=2e(.); Physical(p):0026f086=2e(.); Paged(p):00012086=2e(.); Normal(p):00004ac6=2e(.); RealRAM(p):0020f087=8e(?); RAM(p):0026f087=8e(?); Physical(p):0026f087=8e(?); Paged(p):00012087=8e(?); Normal(p):00004ac7=8e(?); RealRAM(p):0020f088=1e(); RAM(p):0026f088=1e(); Physical(p):0026f088=1e(); Paged(p):00012088=1e(); Normal(p):00004ac8=1e(); RealRAM(p):0020f089=02(); RAM(p):0026f089=02(); Physical(p):0026f089=02(); Paged(p):00012089=02(); Normal(p):00004ac9=02(); RealRAM(p):0020f08a=00( ); RAM(p):0026f08a=00( ); Physical(p):0026f08a=00( ); Paged(p):0001208a=00( ); Normal(p):00004aca=00( ); RealRAM(p):0020f08b=66(f); RAM(p):0026f08b=66(f); Physical(p):0026f08b=66(f); Paged(p):0001208b=66(f); Normal(p):00004acb=66(f); RealRAM(p):0020f08c=83(?); RAM(p):0026f08c=83(?); Physical(p):0026f08c=83(?); Paged(p):0001208c=83(?); Normal(p):00004acc=83(?); RealRAM(p):0020f08d=3e(>); RAM(p):0026f08d=3e(>); Physical(p):0026f08d=3e(>); Paged(p):0001208d=3e(>); Normal(p):00004acd=3e(>); RealRAM(p):0020f08e=e0(?); RAM(p):0026f08e=e0(?); Physical(p):0026f08e=e0(?); Paged(p):0001208e=e0(?); Normal(p):00004ace=e0(?); RealRAM(p):0020f08f=12(); RAM(p):0026f08f=12(); Physical(p):0026f08f=12(); Paged(p):0001208f=12(); Normal(p):00004acf=12() 179 Registers: 180 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 181 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 182 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 183 EIP: 00004aad EFLAGS: 00000a87 184 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 185 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 186 DR6: 00000000 DR7: 00000000 187 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 188 FLAGSINFO: 00000000000000vr0n00OdItSz0a0P1C 189 MMU: Reading from real(r): 00854090=ff (?) 190 Reading from RAM(r): 008b4090=ff (?) 191 Reading from physical memory(r): 008b4090=ff (?) 192 Reading from paged memory(r): 008b4090=ff (?) 193 MMU: Reading from real(r): 00854091=1f () 194 Reading from RAM(r): 008b4091=1f () 195 Reading from physical memory(r): 008b4091=1f () 196 Reading from paged memory(r): 008b4091=1f () 197 MMU: Reading from real(r): 00854092=00 ( ) 198 Reading from RAM(r): 008b4092=00 ( ) 199 Reading from physical memory(r): 008b4092=00 ( ) 200 Reading from paged memory(r): 008b4092=00 ( ) 201 MMU: Reading from real(r): 00854093=70 (p) 202 Reading from RAM(r): 008b4093=70 (p) 203 Reading from physical memory(r): 008b4093=70 (p) 204 Reading from paged memory(r): 008b4093=70 (p) 205 MMU: Reading from real(r): 00854094=09 ( ) 206 Reading from RAM(r): 008b4094=09 ( ) 207 Reading from physical memory(r): 008b4094=09 ( ) 208 Reading from paged memory(r): 008b4094=09 ( ) 209 MMU: Reading from real(r): 00854095=f3 (?) 210 Reading from RAM(r): 008b4095=f3 (?) 211 Reading from physical memory(r): 008b4095=f3 (?) 212 Reading from paged memory(r): 008b4095=f3 (?) 213 MMU: Reading from real(r): 00854096=00 ( ) 214 Reading from RAM(r): 008b4096=00 ( ) 215 Reading from physical memory(r): 008b4096=00 ( ) 216 Reading from paged memory(r): 008b4096=00 ( ) 217 MMU: Reading from real(r): 00854097=80 (?) 218 Reading from RAM(r): 008b4097=80 (?) 219 Reading from physical memory(r): 008b4097=80 (?) 220 Reading from paged memory(r): 008b4097=80 (?) 221 0117:00004ac0 2E 8E 1E 06 00 mov ds,word cs:[0006] RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):00245037=00( ); RAM(r):002a5037=00( ); Physical(r):002a5037=00( ); RealRAM(r):00245036=29()); RAM(r):002a5036=29()); Physical(r):002a5036=29()); RealRAM(r):00245035=a2(?); RAM(r):002a5035=a2(?); Physical(r):002a5035=a2(?); RealRAM(r):00245034=67(g); RAM(r):002a5034=67(g); Physical(r):002a5034=67(g); RealRAM(r):0023a5c6=97(?); RAM(r):0029a5c6=97(?); Physical(r):0029a5c6=97(?); Paged(r):0000d5c6=97(?); RealRAM(r):0023a5c7=00( ); RAM(r):0029a5c7=00( ); Physical(r):0029a5c7=00( ); Paged(r):0000d5c7=00( ); RealRAM(r):00226803=00( ); RAM(r):00286803=00( ); Physical(r):00286803=00( ); RealRAM(r):00226802=2a(*); RAM(r):00286802=2a(*); Physical(r):00286802=2a(*); RealRAM(r):00226801=12(); RAM(r):00286801=12(); Physical(r):00286801=12(); RealRAM(r):00226800=67(g); RAM(r):00286800=67(g); Physical(r):00286800=67(g); RealRAM(r):0024125f=00( ); RAM(r):002a125f=00( ); Physical(r):002a125f=00( ); RealRAM(r):0024125e=8b(?); RAM(r):002a125e=8b(?); Physical(r):002a125e=8b(?); RealRAM(r):0024125d=42(B); RAM(r):002a125d=42(B); Physical(r):002a125d=42(B); RealRAM(r):0024125c=67(g); RAM(r):002a125c=67(g); Physical(r):002a125c=67(g) 222 Registers: 223 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 224 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 225 CS: 0117 DS: 012f ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 226 EIP: 00004ac0 EFLAGS: 00000a87 227 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 228 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 229 DR6: 00000000 DR7: 00000000 230 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 231 FLAGSINFO: 00000000000000vr0n00OdItSz0a0P1C 232 0117:00004ac5 1E push ds RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f090=00( ); RAM(p):0026f090=00( ); Physical(p):0026f090=00( ); Paged(p):00012090=00( ); Normal(p):00004ad0=00( ); RealRAM(p):0020f091=74(t); RAM(p):0026f091=74(t); Physical(p):0026f091=74(t); Paged(p):00012091=74(t); Normal(p):00004ad1=74(t); RealRAM(p):0020f092=13(); RAM(p):0026f092=13(); Physical(p):0026f092=13(); Paged(p):00012092=13(); Normal(p):00004ad2=13(); RealRAM(p):0020f093=0f(); RAM(p):0026f093=0f(); Physical(p):0026f093=0f(); Paged(p):00012093=0f(); Normal(p):00004ad3=0f(); RealRAM(p):0020f094=a0(?); RAM(p):0026f094=a0(?); Physical(p):0026f094=a0(?); Paged(p):00012094=a0(?); Normal(p):00004ad4=a0(?); RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024507f=00( ); RAM(r):002a507f=00( ); Physical(r):002a507f=00( ); RealRAM(r):0024507e=20( ); RAM(r):002a507e=20( ); Physical(r):002a507e=20( ); RealRAM(r):0024507d=a2(?); RAM(r):002a507d=a2(?); Physical(r):002a507d=a2(?); RealRAM(r):0024507c=67(g); RAM(r):002a507c=67(g); Physical(r):002a507c=67(g); Paged(w):0001f19e=97(?); Paged(w):0001f19f=00( ); Physical(w):0020a19e=97(?); RAM(w):0020a19e=97(?); RealRAM(w):001aa19e=97(?); Physical(w):0020a19f=00( ); RAM(w):0020a19f=00( ); RealRAM(w):001aa19f=00( ) 233 Registers: 234 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 235 ESP: 00001e90 EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 236 CS: 0117 DS: 0097 ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 237 EIP: 00004ac5 EFLAGS: 00000a87 238 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 239 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 240 DR6: 00000000 DR7: 00000000 241 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 242 FLAGSINFO: 00000000000000vr0n00OdItSz0a0P1C 243 MMU: Reading from real(r): 00854128=9f (?) 244 Reading from RAM(r): 008b4128=9f (?) 245 Reading from physical memory(r): 008b4128=9f (?) 246 Reading from paged memory(r): 008b4128=9f (?) 247 MMU: Reading from real(r): 00854129=4b (K) 248 Reading from RAM(r): 008b4129=4b (K) 249 Reading from physical memory(r): 008b4129=4b (K) 250 Reading from paged memory(r): 008b4129=4b (K) 251 MMU: Reading from real(r): 0085412a=a0 (?) 252 Reading from RAM(r): 008b412a=a0 (?) 253 Reading from physical memory(r): 008b412a=a0 (?) 254 Reading from paged memory(r): 008b412a=a0 (?) 255 MMU: Reading from real(r): 0085412b=a7 (?) 256 Reading from RAM(r): 008b412b=a7 (?) 257 Reading from physical memory(r): 008b412b=a7 (?) 258 Reading from paged memory(r): 008b412b=a7 (?) 259 MMU: Reading from real(r): 0085412c=01 () 260 Reading from RAM(r): 008b412c=01 () 261 Reading from physical memory(r): 008b412c=01 () 262 Reading from paged memory(r): 008b412c=01 () 263 MMU: Reading from real(r): 0085412d=f3 (?) 264 Reading from RAM(r): 008b412d=f3 (?) 265 Reading from physical memory(r): 008b412d=f3 (?) 266 Reading from paged memory(r): 008b412d=f3 (?) 267 MMU: Reading from real(r): 0085412e=00 ( ) 268 Reading from RAM(r): 008b412e=00 ( ) 269 Reading from physical memory(r): 008b412e=00 ( ) 270 Reading from paged memory(r): 008b412e=00 ( ) 271 MMU: Reading from real(r): 0085412f=00 ( ) 272 Reading from RAM(r): 008b412f=00 ( ) 273 Reading from physical memory(r): 008b412f=00 ( ) 274 Reading from paged memory(r): 008b412f=00 ( ) 275 0117:00004ac6 2E 8E 1E 02 00 mov ds,word cs:[0002] RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):0024504b=00( ); RAM(r):002a504b=00( ); Physical(r):002a504b=00( ); RealRAM(r):0024504a=26(&); RAM(r):002a504a=26(&); Physical(r):002a504a=26(&); RealRAM(r):00245049=f2(?); RAM(r):002a5049=f2(?); Physical(r):002a5049=f2(?); RealRAM(r):00245048=67(g); RAM(r):002a5048=67(g); Physical(r):002a5048=67(g); RealRAM(p):0020f095=06(); RAM(p):0026f095=06(); Physical(p):0026f095=06(); Paged(p):00012095=06(); Normal(p):00004ad5=06(); RealRAM(r):00226003=00( ); RAM(r):00286003=00( ); Physical(r):00286003=00( ); RealRAM(r):00226002=2a(*); RAM(r):00286002=2a(*); Physical(r):00286002=2a(*); RealRAM(r):00226001=52(R); RAM(r):00286001=52(R); Physical(r):00286001=52(R); RealRAM(r):00226000=67(g); RAM(r):00286000=67(g); Physical(r):00286000=67(g); RealRAM(r):00245037=00( ); RAM(r):002a5037=00( ); Physical(r):002a5037=00( ); RealRAM(r):00245036=29()); RAM(r):002a5036=29()); Physical(r):002a5036=29()); RealRAM(r):00245035=a2(?); RAM(r):002a5035=a2(?); Physical(r):002a5035=a2(?); RealRAM(r):00245034=67(g); RAM(r):002a5034=67(g); Physical(r):002a5034=67(g); RealRAM(r):0023a5c2=2f(/); RAM(r):0029a5c2=2f(/); Physical(r):0029a5c2=2f(/); Paged(r):0000d5c2=2f(/); RealRAM(r):0023a5c3=01(); RAM(r):0029a5c3=01(); Physical(r):0029a5c3=01(); Paged(r):0000d5c3=01(); RealRAM(r):00226803=00( ); RAM(r):00286803=00( ); Physical(r):00286803=00( ); RealRAM(r):00226802=2a(*); RAM(r):00286802=2a(*); Physical(r):00286802=2a(*); RealRAM(r):00226801=12(); RAM(r):00286801=12(); Physical(r):00286801=12(); RealRAM(r):00226800=67(g); RAM(r):00286800=67(g); Physical(r):00286800=67(g); RealRAM(r):0024125f=00( ); RAM(r):002a125f=00( ); Physical(r):002a125f=00( ); RealRAM(r):0024125e=8b(?); RAM(r):002a125e=8b(?); Physical(r):002a125e=8b(?); RealRAM(r):0024125d=42(B); RAM(r):002a125d=42(B); Physical(r):002a125d=42(B); RealRAM(r):0024125c=67(g); RAM(r):002a125c=67(g); Physical(r):002a125c=67(g) 276 Registers: 277 EAX: 00010148 EBX: 000000f8 ECX: 00000003 EDX: 00000160 278 ESP: 00001e8e EBP: 00001ea2 ESI: 00000148 EDI: 00001ff8 279 CS: 0117 DS: 0097 ES: 00bf FS: 0000 GS: 0000 SS: 008f TR: 0018 LDTR: 00b8 280 EIP: 00004ac6 EFLAGS: 00000a87 281 CR0: 80000001 CR1: 00000000 CR2: 80113000 CR3: 00286000 282 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 283 DR6: 00000000 DR7: 00000000 284 GDTR: 0000c003887c01f7 IDTR: 0000800a700002ff 285 FLAGSINFO: 00000000000000vr0n00OdItSz0a0P1C
Perhaps some kind of descriptor table building?
