Winevdm
Emulation of old PCs, PC hardware, or PC peripherals.
Re: Winevdm
Postby crazyc » 2019-3-04 @ 04:23
filipetolhuizen wrote:Edit: It just can't run Darkseed 2. The installer takes forever and crashes when it reaches 100% and the game itself also crashes right at startup.
You have to run the game from the install directory not from the start menu (at least for now) for it to start. It will then crash after the start screen which will be fixed if/when this, https://github.com/otya128/winevdm/pull/206, pull request is accepted. Some of the movies won't play unless the video for windows indeo 3.2 codec is installed (the game comes with it but winevdm doesn't support 16bit video codec, you'd need the 32bit version).
crazyc
Re: Winevdm
Postby filipetolhuizen » 2019-3-10 @ 16:41
Thank you all very much. It seems to be the only game that's not working so far (it already wasn't working properly on plain Win7 32 bits). The latest release even fixed a minor issue with Nitemare 3D not showing the start screen if running on 8-bit screen mode.
User avatar
filipetolhuizen
Re: Winevdm
Postby emendelson » 2019-3-29 @ 18:52
I've posted on Github an Inno Setup script that installs Winevdm automatically. Here's a compiled installer:
https://www.dropbox.com/s/daofykx4n9qav ... r.exe?dl=1
You can see the script in an issue post on the winevdm Github site. The installer seems to work, but of course use it at your own risk.
emendelson
Re: Winevdm
Postby abandoSoftware » 2019-4-14 @ 02:52
Is anyone working on this project in this Forum? I would like to report the errors so that errors can be repaired in the future.
This error appears to me, both in games and in programs. Especially in Photoshop 2.5.1.
I imagine it could be something Related to the Visual part.
reporting bug
Second Bug Report. the IBM Lotus R3.0 installer gives problems, impossible to install.
Reporting a third bug . impossible to start the Harvard Graphics 3.0
Fourth report, several bugs.
User avatar
abandoSoftware
Re: Winevdm
Postby emendelson » 2019-4-14 @ 13:50
Feel free to post an issue on the project’s github site so that the devs will see it.
emendelson
Re: Winevdm
Postby collector » 2019-4-14 @ 15:16
abandoSoftware wrote:Is anyone working on this project in this Forum?
Most likely not.
User avatar
collector
Re: Winevdm
Postby abandoSoftware » 2019-4-15 @ 06:07
Most likely not.
Most likely not.
Okay, thanks, I'll leave this last report here, I'll go to Github
User avatar
abandoSoftware
Previous
Return to PC Emulation
Who is online
Users browsing this forum: No registered users and 2 guests
