PCem AMD Ryzen 3700X
First post, by Golf_GTI
I change my CPU i5-4670K for AMD Ryzen 7 3700X and PCem runs the same (the same FPS in games).
Reply 1 of 8, by kjliew
It is great to hear that AMD had finally caught up with Intel on single-thread performance, even though this is on the 4th-gen Haswell core. What more can you expect?
Reply 3 of 8, by Golf_GTI
Does PCem use only one core?
Reply 4 of 8, by robertmo
Yes
Reply 5 of 8, by ShovelKnight
Isn't faithful emulation the whole point of PCem? I mean, if you're emulating a 386, it should provide 386 levels of performance regardless of your host configuration.
Reply 6 of 8, by robertmo
and if you're emulating a Pentium II it should provide Pentium II levels of performance regardless of your host configuration.
Reply 8 of 8, by Silanda
Mine absolutely smokes my old overclocked 3570k.
