Reply 20 of 29, by crazyc
superfury wrote on 2020-02-01, 22:39:OK. So it's basically impossible on a plain XT/AT/Compaq Deskpro 386, except for being able to change the DMA controller by quickly writing the count registers to 0(although it will still transfer 1 byte, which will cause an incomplete command of 1/512 bytes being transferred of a sector, then erroring out?).
Dunno, you'd have to test it yourself.
superfury wrote on 2020-02-01, 22:39:Well, UniPCemu currently just increases the sector numbers monotonically, from 1 up to SPT(as the backend file uses) as it reads it from the backend file. Once it reaches SPT+1(sector>SPT to be exact), it resets back to 1(SPT in DMA mode with MT, otherwise parameter 6 of the command used) with documented head logic(depending on MT bit). It leaves it to the backend file format (either img file or dsk image file) to figure out the data backend and where the sector is on the disk, just requesting said sector id from the disk and retrieving it, assuming it goes on monotonically(e.g. gaps in the sectors available will error out(e.g. read 3 sectors from sector 1 onwards with only sectors 1,3,4(...) defined and sector 2 missing in the backend. Sector 2 will error out in that case when it's reading it(essentially 'passing the index hole twice' as a real FDC would handle it(at least looking at the logical way of finding a sector number on a formatted disk with unknown ordering)))).
To properly support IMD or teledisk you can't rely on sectors being numbered in order like that.
