Tandy 1000 HX Emulation
Reply 40 of 58, by RX9
I would be most happy to be your tester for K6 machines. Although I have the rare K6III+, I believe the architecture is the same for the entire K6 family, except for the added performance enhancements.
Reply 42 of 58, by wd
Rank DOSBox Author
DOSBox Author
Next try. Maybe copy a 0.70 dosbox.conf into the directory and set core=normal
    dbk6_pdm2.rar
    620.57 KiB
    431 downloads
Reply 43 of 58, by RX9
YES! 😀 Thank you all very much. And my offer to be your K6 tester stands. I'm sure you guys have access to my e-mail address due to requirements for signing up, and feel free to contact me anytime. WD: You are awesome and persistent. The latter reminds me of someone else I know. 😀
Reply 44 of 58, by wd
Rank DOSBox Author
DOSBox Author
Sooooo what exactly are you doing with deskmate now? Is it just for fun
or do you have old datasets or something?
Maybe you can play a bit with it and report back if it really works 😀
Reply 45 of 58, by RX9
OK, now for the confession. It is primarily for nostalgic reasons, although I do have a few DeskMate DOC files still hanging around. There are DOS-compatible versions of DeskMate that I can run without DOSBox, but none that offer the HX's Music and Paint programs. That is because DeskMate Music relies on the Tandy 3-voice sound, and Paint will not run with a VGA driver. PDM2 runs perfectly inside of DOSBox except for the notepad and phone accessories for some reason, which is not that big of a deal.
I was a 25+ year manager for RS (left a few years ago), who actually sold the very first model of the TRS-80. For me, this program harkens back to a time that was simpler and more innocent, and when RS was a very different company. When I mentioned in an earlier post that I had written a ton of DOS batch files in my day, I wasn't kidding, as that is what I "grew up" with. It is what also attracted me to your excellent program, and what you offer to people who want to run older software.
Thanks again.
Reply 46 of 58, by RX9
OK, I discovered why the notepad and phone accessories do not work. It is for the same reason that no other files or configurations can be saved or changed: the program does not allow writing to the disk. This is not necessarily a big deal to me, since I was mainly interested in getting PDM2 to work for nostalgic reasons. But if there is something really quick and easy that I'm overlooking, a note of reply would be appreciated. I should point out that adding -freesize "x" and the end of the mount command makes no difference.
Reply 48 of 58, by RX9
The "set comspec" line was enough, put in quotes and added to the command line per the instructions in readme.txt. Once again, WD, you are the man! If there were an award for best DOSBox customer service, it should be yours.
Reply 50 of 58, by RX9
Kudos to all you guys. WD, you asked me to play with the program for a while and report back on its functionality. I have now done so, and I will offer the following in what will likely be my last post on this subject. The fact is that it is 100% working except for one tiny detail. The Paint program calls for use of the F12 key, which does not respond to the program. I seem to recall that the early Tandy keyboards had a slightly different mapping routine than IBM, so I'm quite sure that this is the reason. There is probably a TSR floating around out there that will fix this, but since the mouse can still be used for the function involved, I don't consider it to be worth the effort. In terms of practical functionality, I think that "100%" is still an accurate statement. Once again, this was an excellent effort on the part of the DOSBox team.
Reply 51 of 58, by dvwjr
Unless the Tandy Deskmate software has an option to use IBM scancodes that later Tandy computers supported, it appears that the Tandy 1000 keyboard scancodes would have to be implemented as a DosBox option to support said software.
QWERTY (USA) - Tandy 1000
Scan Kybd
Code Legend normal shift ctrl alt remarks
01 ESC 1b 1b 1b x8b
02 1 ! 31 21 xe1 x78
03 2 @ 32 40 x03 x79
04 3 # 33 23 xe3 x7a
05 4 $ 34 24 xe4 x7b
06 5 % 35 25 xe5 x7c
07 6 ^ 36 5e 1e x7d
08 7 & 37 26 xe7 x7e
09 8 * 38 2a xe8 x7f
0a 9 ( 39 28 xe9 x80
0b 0 ) 30 29 xe0 x81
0c - _ 2d 5f 1f x82
0d = + 3d 2b xf5 x83
0e BACK SPACE 08 08 7f x8c
0f TAB 09 x0f x8d x8e
10 q 71 51 11 x10
11 w 77 57 17 x11
12 e 65 45 05 x12
13 r 72 52 12 x13
14 t 74 54 14 x14
15 y 79 59 19 x15
16 u 75 55 15 x16
17 i 69 49 09 x17
18 o 6f 4f 0f x18
19 p 70 50 10 x19
1a [ { 5b 7b 1b xeb
1b ] } 5d 7d 1d -
1c ENTER 0d 0d 0a x8f MAIN KEYBOARD
1d CTRL * * * * CONTROL MODE
1e a 61 41 01 x1e
1f s 73 53 13 x1f
20 d 64 44 04 x20
21 f 66 46 06 x21
22 g 67 47 07 x22
23 h 68 48 08 x23
24 j 6a 4a 0a x24
25 k 6b 4b 0b x25
26 l 6c 4c 0c x26
27 ; : 3b 3a xf6 xf8
28 ' " 27 22 xf7 xf1
! 29 UP ARROW x48 x85 x90 x91
2a SHIFT * * * * LEFT SHIFT
! 2b LEFT ARROW x4b x87 x73 x92
2c z 7a 5a 1a x2c
2d x 78 58 18 x2d
2e c 63 43 03 x2e
2f v 76 56 16 x2f
30 b 62 42 02 x30
31 n 6e 4e 0e x31
32 m 6d 4d 0d x32
33 , < 2c 3c xf9 x89
34 . > 2e 3e xfa x8a
35 / ? 2f 3f xfb xf2
36 SHIFT * * * * RIGHT SHIFT
! 37 PRINT 10 * 72 x46 SCR PRINT TOGGLE
38 ALT * * * * ALTERNATE MODE
Show last 47 lines
    39    SPACE BAR    20      20    20    20
3a CAPS LOCK * * * * CAPS LOCK
3b F1 x3b x54 x5e x68
3c F2 x3c x55 x5f x69
3d F3 x3d x56 x60 x6a
3e F4 x3e x57 x61 x6b
3f F5 x3f x58 x62 x6c
40 F6 x40 x59 x63 x6d
41 F7 x41 x5a x64 x6e
42 F8 x42 x5b x65 x6f
43 F9 x43 x5c x66 x70
44 F10 x44 x5d x67 x71
45 NUM LOCK * * * * NUMBER LOCK
! 46 HOLD * * * * FREEZE DISPLAY
47 7 \ 37 5c x93 *
48 8 ~ 38 7e x94 *
49 9 PG UP 39 x49 x84 *
! 4a DOWN ARROW x50 x86 x96 x97
4b 4 | 34 7c x95 *
4c 5 35 xf3 xfc *
4d 6 36 xf4 xfd *
! 4e RIGHT ARROW x4d x88 x74 xea
4f 1 END 31 x4f x75 *
50 2 ` 32 60 x9a *
51 3 PG DN 33 x51 x76 *
52 0 30 x9b x9c *
! 53 - DELETE 2d x53 x9d x9e
! 54 BREAK x00 x00 * * CTRL BREAK is the ctrl brk
routine
ALT BREAK is the scroll lock
! 55 + INSERT 2b x52 x9f xa0
! 56 . 2e xa1 xa4 xa5 NUMERIC KEYPAD
! 57 ENTER 0d 0d 0a x8f NUMERIC KEYPAD
! 58 HOME x47 x4a x77 xa6
! 59 F11 x98 xa2 xac xb6
! 5a F12 x99 xa3 xad xb7
Keyboard layout:
F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 + - break
esc 1 2 3 4 5 6 7 8 9 0 - = backspace alt print 7 8 9
tab q w e r t y u i o p [ ] hold numlk 4 5 6
control a s d f g h j k l ; ' enter up home 1 2 3
caps shift z x c v b n m , . / shift left down right 0 . enter
space
dvwjr
Reply 52 of 58, by wd
Rank DOSBox Author
DOSBox Author
At the moment the scancode layout is (mostly) that from enhanced keyboards,
maybe this should be selectable/configurable to have normal scancodes
(like bochs) and tandy1000-compatible ones.
Reply 53 of 58, by swaaye
I started out computing on a Tandy 1000 TX. Seeing Deskmate running is something I haven't seen in about 15 years now. It's funny to see Desk Mate telling you it's June 5, 2007! Thanks for all the effort WD! 😀
Now I'll have to waste hours setting up a DOSBOX install with some of my old games. Space Quest 3, Arctic Fox, Stellar 7, Battle Chess... I had a friend with an IBM XT and it was just glorious to compare Tandy 16-color to CGA. He didn't even have a hard drive, while I was loaded up with a 20 meg hard card! Heh heh...
I wonder if I can find Lotus Symphony. I still have DOS 3.20 on a Tandy low-density 3.5" too.
BTW, in paint, you can just do Ctrl-Q to quit instead of F12.
Reply 54 of 58, by RX9
Ctrl-Q takes you all the way out of the program, whereas F12 was designed to return to the "tools" menu, so it is not quite the same. As I said earlier, you can always use the mouse on the bottom of the canvas page to effect a return to "tools," but there does seem to be one exception. Engaging the "text" tool has the effect of temporarily disabling the mouse as soon as the cursor is positioned, and not even Ctrl-Q is functional. It would appear that this is the one instance where "F12" would come in handy, as the only choice is to then Ctrl-F9 out of the entire DOSBox environment.
I knew it was stupid to suggest that my prior post might be the last. But it's also nice to know that I'm not the only DeskMate freakazoid out there. Amazing what they could put on a single 720K diskette in those days.
Reply 55 of 58, by RX9
I have discovered another little quirk that was unexpected. In order to have full write capability with no apparent restrictions, the drive must be set to "A" for PDM2 and designated as a floppy. I have successfully done this with manual entry, but I can't seem to figure out how to do it all from a single command line. Is it possible to mount a floppy A drive and execute a command from that drive simultaneously? If so, any help with the syntax would be appreciated.
Reply 56 of 58, by MiniMax
Rank Moderator
Moderator
dosbox -c "mount A C:\some\folder -t floppy" -c "A:" -c "pdm2"
_________________
Reply 58 of 58, by dvwjr
I think you are correct. No way around having a Tandy specific key-mapping at the scan-code level. Market forces eventually made Tandy adhere to the IBM PC-AT & PS/2 101-key standard. The option to support the original proprietary Tandy keyboard should probably be done when some-one has the time.
Right now I'm too busy trying to fix the DosBox v0.70 MIDI handling for the rev00 MT-32 Roland synth and getting my SYSTEM SHOCK v1.5P install finished... 😁 I'm sure a volunteer will appear later..
dvwjr
