Carrera wrote:This is for DOS and Windows games so not sure how/why Linux would help.
Win98 usually gets the information from the PCI configuration space, so it should be correct. Although there are some manufacturers (usually of cheap clone hardware), who store incorrect or incomplete PCI IDs.
I did not mean _installing_ Linux, just booting up a LiveCD will do the job. The kernel usually is very verbose with hardware information and most LiveCDs include diagnostic tools, which could help in this case.
But it probably only would have been practical if you already had a LiveCD lying around... so just forget about it 😀
