First post, by QBiN
- Oldbie
Hey Folks...
I need some advice. I'm hoping one of you may have seen a product that fits my needs or maybe a home-grown solution.
Setup: Some of you know that I have a retarded (read: extensive) collection of old systems. Most are traditional AT based (AT PSU's), while just a couple of the newer ones are ATX based and have ATX PSU's. All these systems are hooked up to KVM's. So controlling them is no problem.
Problem: Reaching the power switch (AT) or power button (ATX) on all these systems when I want to use them is a huge pain. I'm looking for a way that I can remotely power-on/power-off these systems.
I've seen some IP-enabled powerstrips in the past that can be managed remotely to toggle power on individual AC sockets. That would work for the AT systems. But that doesn't do anything for the ATX systems since they use a soft power-on/off.
Any ideas? Suggestions? Since I can already controll them (via the KVM) from one master station, the goal is that I would be able to remotely power them on/off from one location too.
