First post, by support@lmicanada.com
I have a basic program that is being run on a Win95 desktop as well as a couple ancient handhelds for data aquazition. The data is transfered by RS232 on Com 1:
I need to run the program on a WinXP Pro box first, and eventually on WinXP laptops without com ports (use PCMCIA com port or USB/Comm: adapter)
Any advise (other than rewrite the program in VB?)
Thanks
Reply 1 of 6, by elianda
Typically you can open a filename "COM1", this should open the Serial Port as configured in Win device manager. It's a synonym like LPT for parallel a.s.o.
I don't know much about modern basic, but you should be able to
print# and get# chars or bytes then from there.
In C it would be CreateFile , ReadFile and WriteFile...
If you really want to stick to Windows you might want to have a look at the Win32 SDK and there ComCTL , DCB a.s.o....
A USB to RS232 adapter is typically mapped to f.e. COM3 by a wrapper USB driver.
Reply 2 of 6, by elianda
I forgot, you can still access the uart in hardware from the dosbox, all accesses will be mapped through.
16550 manual: http://www-s.ti.com/sc/ds/tl16c550c.pdf
Works with any other 16550 too including auto flow.
Only other thing is that you have to set the PIC if you use a PC.
You can take this part from some example, there are alot available.
Reply 5 of 6, by DosFreak
Good to hear....and thanks for reporting back. 😀
I wonder if the free Microsoft Virtual Server 2005 (not as easy to use as VPC but compatibility-wise should be the same), the free Vmware Server Beta 2 or the OpenSource Qemu would have solved your problem though. 😉
Make your games work offline
Reply 6 of 6, by support@lmicanada.com
Quite possible Qemu may have worked, but the other two products are considerably more complex to use. The PITA factor would more than balance out the cost, being a customer application. Using the VPC is pretty much a no-brainer - it was dead easy to set up, and the 45day free trial made it risk free. I was able to try it and prove it worked without spending any cash, and it's cheaper for the customer than re-coding the program.
