First post, by fermaf
Hi I just installed dosbox in my Linux Ubuntu dapper.
It works properly, but there's a problem with an old ISA (non-commercial) card.
I have too a DOS program who processes data read from this ISA card.
When I start dosbox I can run my DOS application, but It does not see any ISA Board.
I assume that I have to configure this device in config file used by dosbox, but I don not where to start.
The ISA card is eeprom reader/writer Built in the 90's for a school student, the DOS software too.
When I run the program in a DOS 5.0 machine I go directly to the software directory and run the exe file. Theres no special configuration un autoexec.bat and config.sys files.
Please Any help?
Reply 1 of 1, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
No chance unless you have some programming knowledge.
1+1=10
