First post, by lfo2k
hello dear dosfriends 😀
i have got a problem with my yamaha db-50xg wavetable (on a sb16 ct2290)
the wavetable seems to be in the wrong modus.
a example: in day of the tentacle, just at the beginning, first room, where the clock is. instead of a "tick-tack" it makes a piano sound.
another game... start trail2 (dsa2 sternenschweif) at the beginning in the tempel, there is also a bothering "piano", where another instrument should appear.
if i do a gm-reset (general midi) everything is ok. then all sounds appear right.
same if i first play doom. (doom seems to start a gm-reset)
is there a way to put the wavetable permanent in the gm-mode?
i dont want to play every time first doom, to hear the propper sounds in day of the tentacle or startrail2.
greets out 😉
